Go to Post I feel like watching match videos from 2003 could be considered a form of cruel and unusual punishment. - Cory [more]
Unread 01-03-2008, 20:40
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
Drivetrain Questions
Hey there CD, just thinking of some drive train ideas. and was wondering how to do a few things
had a few questions:
what is the best way to tension toothed belt/roller chain?
we have had real problems with chain and belt tension in past robots and it's a problem i want to try and address next year
and....
does anyone have cads, or dimensions on the new XRP dewalt transmissions (they don't sell the old ones) available?
Unread 01-03-2008, 21:14
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Rookie Year: 2007
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Re: Drivetrain Questions
We used some short pieces of 80/20 and put some roller that we attached to it you can kind of see it here
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 02-03-2008, 22:58
Jaybee1405
Posts: n/a
Your best bet is to use adjustable tensioners, as chains (and probably belts, although I have hardly any experience with them) will stretch as the competition wears on. I would suggest a sliding idler sprocket (nylon is good).
There's lot of threads on this subject so a quick search would also be helpful.
Unread 02-03-2008, 23:09
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
this year we managed to find on ereplacementparts.com the old style drill to interface onto a fisher price, some parts took awhile to get here however. you can still buy the old drill
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 02-03-2008, 23:27
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
Chains, you can typically do with some kind of delrin runner or wheel that is adjustable and easy to access for spot checks and tensions between matches. you can also use a screw tensioning system where you draw back or push froward a block that either holds you wheel or sprocket.
Belts are basically the same and require good tensioning practices to continue to work properly, if not they are liable to break. we on 48 have used basically the same method ever since '06 on our treads and have only broken a few pairs since. it involves putting a screw tensioner into the system, but instead of moving one of your delrin wheels or an idler sprocket you are moving a splined toothed pulley.
I don't have the models or any pictures on my computer but I know of a few people who, if you ask nicely will help you out. one of them is Mike Mellott, he was the head designer on our past couple of models for treads and we be the one to tell you how to use some form of screw tensioning system, the other two I don't know personally but probably know allot more than I do about drive train design and they would be, Craig Hickman and Madison Krass. look up some of they're work, I know one of them has a 6-wheel drive with a build in tensioner. remember they are probably busy with schooling and they're teams so do searches and some research before asking for explanations. most of the material can be found on CD.
I will try to find some of my old material and post it also.
Unread 02-03-2008, 23:34
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
and....
Here's how we tensioned our chain this year:
http://www.chiefdelphi.com/forums/sh...ad.php?t=64009
On the right is our drivetrain tensioner which we haven't had any problems with at all. It's continually adjustable just by moving the shaft up and down and tightening the position with two nuts on top and bottom. The only time our chain jumped off is when one of our IFI wheels failed. The hole for one of the wheel bearings expanded by about 3/16", and caused the wheel to wobble all over the place (hence the chain jumping off) so we had to replace the wheel.
On the left is #25 chain tensioned by a turnbuckle, which actually failed right before ship day because the eye loop that we had closed, opened up. We ended up hacking on a hose clamp to pull the van door motor shaft up - not the most elegant solution, but it works.
Our team used the DC940s this year on the drivetrain with great success. The main difference is that the hole pattern on the yellow housing is slightly larger. 624 was gracious enough to post the dimensions so we were able to start making the parts even before our transmissions arrived in the mail: http://www.chiefdelphi.com/forums/sh...9&postcount=17
The dimensions of the piano wire linkage may also need to be adjusted, we made ours to fit and didn't really look at any dimensions.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Last edited by Richard McClellan : 02-03-2008 at 23:55. Reason: added paragraph about tensioner
Unread 02-03-2008, 23:42
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
We added an idler gear that we could adjust and we have never had the chain slip (we put it in during week 3, and we never had any problems yet...).
Here's a picture:
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
Drivetrain 1727 bobdahaxor Robot Showcase 18 01-02-2008 14:57
drivetrain!!! hiimcristhian General Forum 3 12-01-2008 23:51
Questions about an Idea for a drivetrain. Radiator251 Technical Discussion 21 29-01-2006 13:11
Drivetrain Hawk135 Technical Discussion 3 06-01-2003 22:14
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
