Go to Post I decided I would keep coming and it just kept getting more and more fun. By the time build season started going I couldn't have quit if I wanted to ^_^ - Mr. Pockets [more]
Unread 02-03-2008, 01:33
dunkonu dunkonu is offline
dunkonu is an unknown quantity at this point
Motor Driver Selection
Hi,
I have chose the motor for self-balancing scooter. The spec of the motor can be seen in the attachment file.
Right now I have to choose which driver is suitable for my motor. I have narrowed down to three drivers and the specs are:
Type: LW24VFR
Weight: 540g
L*W*H: 120mm*98mm*41mm
Current Limit: 75A
Continuous Current: 20A
Direction: Forward/Reverse
Nominal Battery Voltage: 24Vdc
E.M Brake(24Vdc): None
Suitable Motor: 600W Below
Type: LW24VGB
Weight: 1KG
L*W*H: 162mm*115mm*56mm
Current Limit: 120A
Continuous Current: 40A
E.M Brake(24Vdc): Yes
Type: LW24VG
Weight: 880g
L*W*H: 142mm*115mm*56mm
Current Limit: 70A
Suitable Motor: 450W Below
Can anyone give me some ideas or suggest which driver is the best match with the motor? Why?
Thanks
Name:	PT1188 Motor-2.jpg
Driver Selection Mousepad General Forum 23 26-02-2005 18:36
Help with driver selection LBK Rules General Forum 28 04-02-2003 18:04
Motor Selection vtome Motors 2 11-01-2003 09:50
DRIVER SELECTION.... archiver 2001 11 24-06-2002 00:02
Driver Selection archiver 2000 7 23-06-2002 22:05
