Help with the IR board
First off let me say that our IR board doesn't work at all. We cannot even get anything to happen when power is applied. So i was wondering where we could get a new one bcuz i've checked everywhere.
Re: Help with the IR board
It could be a couple of different things causing the problem
1) The +5 vdc regulator is shot. Replacing it will fix that issue. 2)The code in the board might be corrupt. There will be people at the regionals that can re-program the board. There is another option. Kevin Watson has written code that uses a simple VISHAY sensor to entirely replace the IR board. $2 for the sensor, one PWM cable and ten minutes of coding and you should be good to go. This "Sticky" post has all the details. |
request one using CD-swap, at your competition request one over the PA if anyteam is willing to give you theres or else create a hybrid without using the IR
RE-5v regulator failures:
If you take pin 2 on the ICSP header and run it to a 5v source on the rc, you can bypass the regulator, and make it work. I'm not sure if its reccomended or not, but in a pinch it works. |
If you checkout the IR schematic in the documents on the First website you will see a note on what to remove and what to add to use an external 5 volt supply.
I wonder why they designed it with a 5V regulator, when they knew we would be connecting to our RC anyway...
They give you the option of connecting to a 7.2-12 volt source with regulator or to a 5 volt source without the regulator. Your choice depending on application with the RC (Backup battery) or a custom circuit using a local 5 volt supply. Crafty devils these designers!
| need help with ir board | shumajax | Electrical | 2 | 04-03-2008 16:19 |
| Figure out what's wrong with the IR board | sparrowkc | Electrical | 5 | 17-02-2008 12:29 |
| HELP!!! STUCK WITH SUB ROUTINES WITH THE IR!!! | drewjones13 | Programming | 1 | 17-01-2008 20:52 |
| Do you have a problem with the IR Board? | DonRotolo | Control System | 5 | 07-01-2008 23:57 |
| Please help me with the size of the rotating light!!! | bigqueue | Technical Discussion | 5 | 21-01-2002 09:40 |
