Go to Post [You know you've overdosed on FIRST when...] When you discover that the cure to the swine flu is "oink oink BOOM!" - Katie_UPS [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 05-03-2008, 16:08
703Trombley703's Avatar
703Trombley703 703Trombley703 is offline
FRC #0703 (Pheonix)
Team Role: Mechanical
703Trombley703 is an unknown quantity at this point
Send a message via AIM to 703Trombley703
School project suggestions
Hi I am doing a senior project for my high school and i was hoping i could get several hints. My idea is to make carbon fiber shin guards for soccer. I am not sure what to use. There's sitka spruce wood, honeycomb, or davinacel foam, or just find a light weight plastic piece.
Any ideas or suggestions will be helpful
Unread 06-03-2008, 08:27
MegaSparks's Avatar
MegaSparks MegaSparks is offline
FRC #2062 (C.O.R.E.)
Rookie Year: 2007
MegaSparks will become famous soon enoughMegaSparks will become famous soon enough
Re: School project suggestions
Make sure the product you end up using has been tested for biocompatibility and human skin contact for less that 24 hours. Some materials can cause skin irritations so that is why many shin guards have a pad inside to go between the guard and the skin.
You can find this out by using the UL product certification number ( 6 digit number following the UL logo) of the material and search the data base at UL (http://database.ul.com/cgi-bin/XYV/t...AME/index.htm). This number is entered in the "UL File Number" field. In the certification it will state compliance to ISO 10993 for limited contact, this is what you need.
Good luck and I really like the senior projects that help the less fortunate and extend GP and FIRST into the community beyond robotics.
Unread 06-03-2008, 23:12
FRC #0703 (Pheonix)
Yeah I was planning on placing a polyester padding behind the carbon fiber. Also I am still trying to figure out what I should use for the inner core. Hence looking for suppliers I have started to think about using an eighth inch honeycomb but its the matter of finding a decent price and I know for a fact that would be the lightest way i could think of. Unless there are other products that are just as light and have a lower price.
Originally Posted by AndyH View Post
I would suggest that you contact your local EAA (experimental aricraft association) chapter. Many Experimental builders have a lot of experience with carbon fiber and othe composite fabrication. There are a lot of little tricks and things to make it easier. Most of these guys are more than willing to help. I have learned a lot form Corvette guys and airplane builders.
Good luck
Yeah thats a great idea, I never thought of that. Thanks for the suggestions.
Also if there is anything else that i would be missing please let me know. Anything will be helpful
Last edited by 703Trombley703 : 06-03-2008 at 23:14. Reason: Forgot to finish writing to others.
Unread 06-03-2008, 08:40
AndyH's Avatar
AndyH AndyH is offline
FRC #1098 (Rockwood Robotics)
AndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud of
Good luck
Help w/school project (was: Plz Reply ASAP..) bilal1219 Programming 8 10-06-2007 14:36
School Project Paul E. Lathrop Inventor 7 16-04-2007 23:01
Suggestions for a middle school robotics curriculum Lisa Perez General Forum 13 25-07-2006 21:10
Team Poll For School Project talldude1412 General Forum 5 23-02-2006 14:59
homemade speed controlllers (for school project) Denman Electrical 26 18-04-2005 11:07
