Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 06-03-2008, 09:11
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
4V - 5V signal on Digital Input
We have an input signal that is at 4V when it is low, and at 5V when it is high. How could we bring the voltage down so that we can read it in as a digital input?
And no, analog inputs are not an option
Digital out signal speed on off, almost like PWM but at max 60Hz Generalx5 Electrical 2 27-03-2007 12:26
Auton digital input ten3brousone Programming 7 20-03-2005 22:23
digital input question... Kevin Karan Programming 9 12-04-2004 07:34
counting digital input CharlieWilken Programming 9 22-03-2004 19:56
Robot Digital Input Mike Norton Technical Discussion 5 16-01-2003 14:31
