Go to Post People... chill. It is week 1. Recall week 1 last year when many teams said "no one is capping with the 2x ball"... "only a few teams are hanging". - Andy Baker [more]
Unread 09-03-2008, 14:56
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
USB to 9-Pin Serial Conversion
No, I'm not talking about the USB Dongle.
I spent a week in Rolla over last summer for an Intro to Engineering Camp and in the Computer Engineering presentation, I got a small 3''x3'' circuit board with a cheap little microprocessor built in. The IO consists simply of four switches, four LEDs and a basic speaker. I'm going to replicate it a few times so each of our prospective programmers for next year can play around with them and get a feel for how microcontrollers work. The board utilizes a 9-pin serial port for program loading, much like the FIRST RC. Our school provides laptops for every student (except our Senior class. We were the last class to not get them), but none of them have a 9-pin serial port.
I know the basic background of how the 9-pin serial port works (RS232, I believe. Correct me if I'm wrong), but USB is very sketchy. I figured someone around here knows enough to help me. Am I correct in saying that USB is basically a 4 pin serial port that uses a +5V pin, a Tx pin, an Rx pin, and a Ground pin? If so, could I make a custom cable that wires the USB's Tx to the 9-Pin's Rx (In addition to using 9-pin serial, the board is designed so that you have to use a Null-Modem cable), and so forth?
Code:
RS232        USB
1:DCD        +5V
2:RxD--------Data-
3:TxD--------Data+
4:DTR      |-Gnd
5:Gnd------|
6:DSR
7:RTS
8:CTS
9:RI
I'm just hoping I don't have to actually go out and buy USB to 9-Pin Serial converters for everyone. I bought one for myself a while back, before I knew a whole lot about this stuff (though I still don't), and if I remember correctly, buying one for every member might get expensive.
Code:
void function(void)
  function();
Unread 09-03-2008, 15:09
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: USB to 9-Pin Serial Conversion
Sorry to be the bearer of bad news, but you do. There is no easy way to connect a RS232 device to your laptop's USB (you may very well frag something if you wire it up per your diagram).
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 09-03-2008, 15:13
void* Jake;
FRC #1178 (DURT)
Kinda thought so.
At the least, can anyone explain how USB actually does work?
Code:
void function(void)
  function();
Unread 09-03-2008, 16:29
DonRotolo's Avatar
Back to humble
FRC #0832
There are lots of resources online to tell you that.
What is important here is that RS-232 uses +12 and -12 volts for signaling, while USB does not. RS-232 uses one wire for "transmit" and one wire for "receive", USB uses two wires as a differential pair much like CAN Bus.
So yes, you need those converters.
Unread 09-03-2008, 18:59
jzampier's Avatar
jzampier jzampier is offline
Finger Lakes Regional Staff
AKA: Jeffrey Zampieron
no team (-)
jzampier is on a distinguished road
Send a message via AIM to jzampier
The USB specification is IIR freely available (and several hundred pages). There is quite a bit that goes on at the MAC and PHY levels which software does not, typically, have control over. RS232 has none of that.
I recommend a little dongle. Blackbox makes some nice multi-port ones, as do other companies. I'd avoid anything with a prolific chipset, the FTDI chipset is better.
Hobby Engineering, http://www.hobbyengineering.com
Sells some modules for integration if you are interested. I've used them for projects before and they work pretty well. Drivers for windows and linux.
"Put your hand on a hot stove for a minute, and it seems like an hour.
Sit with a pretty girl for an hour,
and it seems like a minute. THAT'S relativity." -Einstein
First Resume: (If I can remember)
2001 NJ Regional
2001 Championship
2002 NYC Regional
2003 OH Regional
2003 Championship
2004 OH Regional
2005 Finger Lakes Regional
2006 Finger Lakes Regional (yes!)
Unread 09-03-2008, 22:36
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
I broke down and had to buy one yesterday. We have had to use a Pentium 2 since 2000 to program our bot simply b/c of the serial port.! It cost me $36.99 at BestBuy.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 09-03-2008, 22:43
mormannoob's Avatar
mormannoob mormannoob is offline
President and Senior Programmer
AKA: Clinton
FRC #0498 (Cobra Commanders)
mormannoob is on a distinguished road
Any word if IFIs new controllers are still serial or not
Why cant code work the first time
Wait I have to lead programmers thats like asking a kid who doesnt know how to ride a bike to lead a group of guys at the tour de france
Unread 10-03-2008, 11:27
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
From what I've heard IFI is not providing the new controller(s)
But IFI plans to release a WIFI Vex Controller
Unread 10-03-2008, 12:48
FRC #2429
From what I've heard, Intelitek has signed a non-disclosure agreement that states they won't discuss anything related to the new control system with outside parties.
-Kevin
Kevin Watson
http://kevin.org
Unread 10-03-2008, 13:48
Kingofl337's Avatar
AKA: Adam
Rookie Year: 1998
Anything I have heard has been on these threads...
I have heard nothing as far as intelitek is concerned, if that is incorrect I'll gladly remove it....
-->http://firsttechchallenge.blogspot.com/
USB To Serial Devo1098 Programming 3 30-06-2007 19:51
Using a USB to 15 pin converter gillejr Control System 7 29-01-2007 20:44
BAFO USB to 9 Pin Adapter Skiguy523 Programming 2 29-01-2005 01:49
USB to 9-pin serial port (HELP!!) n00b Technical Discussion 10 01-02-2004 21:25
USB to Serial Jack Programming 24 23-12-2002 14:21
