Signalling voltage question
Hey all,
I have somewhat of an interesting question/problem. I am trying to interface a Handspring Visor (a very old PalmOS device) to the dashboard port on the OI. Now, the way I understand it, the OI's port is a standard RS-232 port. That would imply it is signalling at, like, +/- 12 volts, wouldn't it? The port on the Visor demands 3.3v, and I think that's a maximum, not a minimum. Is there an easy way, other than trying to track down a serial dock, to do the hardware interface here? I know which pins are the serial pins on this device, but I don't want to fry it with 12 volts. EDIT: Forgot to mention, I am definitely cracking the device open, so the physical interface is not a problem. I am developing software for it, and this will be open-source for future teams if I get anywhere with it. It's the perfect dashboard device--small, lightweight, battery lasts *forever* and has audible and visual feedback. And an open SDK to boot. I just don't know enough about the electrical side. I understand there's a way to drop voltage with diodes/a resistor but I don't understand it fully. Perhaps an experienced EE can help me... Thanks in advance, JBot EDIT2: Ohh! I could just use a MAX232 couldn't I? Last edited by JBotAlan : 10-03-2008 at 20:15. |
Re: Signalling voltage question
You are correct; the dashboard port on the RC signals at +/- 12V. It does this by using a little IC known as a MAX232.
The MAX232 is a voltage level translator specifically designed for the RS232 standard. A quick Google search on the chip number will turn up a datasheet. Use is quite straightforward--after connecting a few required capacitors, connect the RS232 RX pin to the RC dashboard port, and the LVTTL RX pin to your handheld's RX pin. Best of all, you can request a free sample of the chip in a DIP package from Maxim's website at www.maxim-ic.com! Hope this helps... Eldarion EDIT: As mentioned below, the MAX3233E is definitely a better choice for this application. Having cut my teeth on the venerable MAX232, I tend to use it for everything... ![]() Last edited by Eldarion : 10-03-2008 at 22:02. |
Almost. But the MAX232 chips need a 5V supply and thus have 5V TTL outputs. Not toooo likely to fry your Visor, but if you're already going to the trouble I think you more likely want something along the lines of the MAX3232E which can operate from a 3.3V supply.
EDIT: In line with Alan's suggestion, there's also the MAX3233E hat doesn't require external caps but still runs off 3.3V Last edited by Kevin Sevcik : 10-03-2008 at 20:46. |
Steve Last edited by Steve_Alaniz : 11-03-2008 at 09:02. Reason: rethought |
Thanks. I have ordered a sample; I'll see if it works for me when I get it.
JBot |
| Signalling Methods during Hybrid | 114Klutz | Programming | 6 | 07-03-2008 15:19 |
| Quick question relating voltage across compacitor | Adam Y. | Math and Science | 2 | 11-11-2005 19:39 |
| OI Voltage | JAH | Electrical | 7 | 12-11-2004 20:01 |
| Battery voltage | Josh Siegel | Programming | 5 | 22-12-2003 10:15 |
| Voltage Byte -> True Voltage | Ulibrium | Technical Discussion | 11 | 01-03-2002 08:55 |
