Go to Post We make ourselves better by lifting others and standing on their shoulders, not by knocking them down. - Taylor [more]
Unread 12-03-2008, 06:21
eng_tarekwaheed eng_tarekwaheed is offline
eng_tarekwaheed is an unknown quantity at this point
Red face help please
i wanna to know how can i use the optical mouse as position feed back in details quiclu please
Unread 12-03-2008, 06:43
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Re: help please
All the mouse really consists of are two encoders, one along x, one along y. Wire both of them (to dig IO, set to in) and then set up an interrupt to count their ticks. Figure out how many ticks/inch or ticks/foot or there are (drive the robot 10 feet, and have the robot printf the ticks).
Then use that data to tell the robot to go n ticks. If you only want to travel along x, then use the y axis as "error", and if the robot picks up travel along y, have it autocorrect.
Did that make sense?
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 12-03-2008, 07:44
Re: help please
i wanna know how can i put the mouse and get its power
Unread 12-03-2008, 07:56
Re: help please
i wanna know also the circuits contact with the mouse
Unread 12-03-2008, 09:01
Re: help please
Unread 12-03-2008, 11:59
AKA: Jimmy Cao
Re: help please
Unfortunately, I am not familiar with which pins do what on a mouse. You should probobly either contact a manufacturer or dissassemble an old one to figure out what goes where. You will need to definately wire up the power (prob 5 volts) and ground. There should be 2 digital lines for the encoders, and (at least) 2 digital lines for the clicks (maybe one more for the wheel). You will not need to use the clicks or the wheel, so do not wire them.
To test, check for continuity or resistance through the mouse as you move it back and forth, and see if the line ever reads high.
It wont be easy. I know (at least) one team used a mouse, so they may know better than I do.
Jimmy Cao
Unread 21-03-2008, 15:15
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: help please
Depends what kind of mouse too. A PS/2 Mouse just has a Data, Ground, Power and Clock lines (source: Wikipedia).
If its USB there are four pins: Power, Ground and Data+, Data- (source: Pinouts.ru).
So either way I don't think its as simple as just see which lines go high, I'm pretty sure its all encoded as pulses along the data lines.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
pic: please help us please mortals CD47-Bot Robot Showcase 5 25-01-2004 11:03
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
please help us, pretty please :) archiver 2001 0 24-06-2002 03:13
