Go to Post Note that these comments are based on the 2006 FRC game rules, and they may or may not apply to the 2007 game. Your mileage may vary. - dlavery [more]
Unread 12-03-2008, 09:26
arhajder's Avatar
arhajder arhajder is offline
Arkadiusz Hajder
FRC #0640 (Viro)
Team Role: Leadership
arhajder will become famous soon enougharhajder will become famous soon enough
Send a message via AIM to arhajder
Wiring Gyros
We are trying to wire our 08 gyro but not exactly sure how its supposed to be wired. So far we soldered on two pwms with the male end cut off. Are we supposed to connect both pwms to the analog iuput or something else?
Unread 12-03-2008, 11:32
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Re: Wiring Gyros
Yes, they go to the analog inputs. You should have black to the inputs marked G/B and red on the inputs marked 5/R. The white wire goes to the R/W input on one side and the T/W input on the other side.
The T analog input gives you the rate of turn and the R output gives you the relative temperature. I believe the temperature is used to calcuate a correction factor, as accellerometers will vary as the temperature changes. We did not hook up the temperature output ourselves, we only looked at the turn output.
Did anybody else use temp for correction? What's the formula? (I know, its probably in the datasheet)
Brian
Brian K
Team 1225 Robotics Mentor
Wiring Gyros and Encoders? SuspectZero Electrical 3 03-02-2008 15:30
Gyros EROCK Kit & Additional Hardware 10 21-01-2008 18:58
Gyros Ryan Cumings Programming 0 26-01-2004 16:22
Gyros!! RAWdealer59 Programming 1 12-02-2003 16:46
Gyros archiver 2000 3 23-06-2002 22:58
