Go to Post Computers have a nasty habit of doing exactly what you tell them to do instead of what you want them to do. - KenWittlief [more]
Unread 12-03-2008, 14:31
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Microphone intergated on to a FIRST RC?
We need to integrate a microphone into the RC, but I have no idea how or what I should use. We really don't need to hear clearly all we need to hear is morse code. Does anyone have any Idea how?
I was hoping to use the IFI dashboard.
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 12-03-2008, 23:07
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Microphone intergated on to a FIRST RC?
John,
What you might want is a mic preamp. It is fairly easy to build one with parts from Radio Shack. An LM324 is a quad opamp optimized for a single ended power supply. What you might want to add to this arrangment is a DTMF emitter with a DTMF decoder following the preamp. This will give you a digital type output where you can use one of 10 switch closures. Morse code is OK but it is difficult to decode unless the code is generated through an electronic device that has controlled timing. Morse readers are available but are fairly complex devices as you problably know. DTMF decoders have built in filtering that will help in noisey environments. Several vendors sell kits for this. Ramsey I think has a few different kits. They are the ones that make some nice little devices for hams and they have an internet site. You also might want to check out MCM.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 12-03-2008, 23:25
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Au contraire! If you have a clean signal with no significant "bounce" on the leading or trailing edge of the dits and dahs, reading hand-generated Morse code is remarkably simple.
One of my first programming projects as a youngster was a speed-adaptive Morse decoder. It usually took about three characters to figure out the difference between e.g. C and TETE, and then kept perfect sync through up to a 2:1 speed change between characters. PM me for the algorithm if you're interested, and I'll try to remember it well enough to explain it.
Unread 13-03-2008, 06:10
Unsung FIRST Hero
Rookie Year: 1996
My point exactly. Noisey accoustic environment, excited Morse sender, and non standard and non repeatable timing all add up to unreliable Morse decoding. To send three characters to get the decoder to track and then recognize what is sent would take most or all of the auto period at the send rate of an inexperienced operator.
Al
WB9UVJ
www.wildstang.org
Unread 13-03-2008, 11:18
Engineer's Avatar
Engineer Engineer is offline
KØBR
AKA: Rick - KØBR
FRC #3007 (RoboTitans)
Engineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of light
There is some pretty good free CW decoder software out there on the Internet. One that I've used is CWGet. Look in some old issues of QST (If you know of a ham radio operator that is a member of ARRL) as I seem to remember a article comparing several programs about two years ago.
2008 GM Industrial Design Award (2232)
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW -- What A Ride!" Anonymous
Hello, from KØBR.
Unread 13-03-2008, 12:40
N7UJJ N7UJJ is offline
Teacher
AKA: Allan Cameron
FRC #5465 (BinaryBots)
Team Role: Teacher
N7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond repute
I think the source for the Morse code request is from FIRST students who will be entering the underwater robot contest, NURC, in June. One of the tasks is to decode a repeating 5 words per minute, 3 letter airport code (eg PHX PHX PHX...). The speaker is approximately 12 feet underwater, at night, and is one of many taks that the teams can earn points.
4. You must activate the origin beacon button which will be lighted due to the system being armed and waterproof. The button will also be labeled to aid in finding it. Once the button is pressed, a Morse code tone will begin repeating a three letter airport set of initials to indicate the airport of origin. An underwater speaker will be located on the dashboard of the cockpit near the activation button of the origin beacon.
There are many strategies to "hear" and decode 5 wpm Morse underwater. It will be interesting.
Unread 16-03-2008, 11:52
Unsung FIRST Hero
Rookie Year: 1996
John and Allan,
This will bring into play a new set of problems. There are a variety of waterproof and water resistant mics available. You are going to have to search. The military has been using mics that can be used in all kinds of harsh environments. Mil surplus dealers may have some in stock that you can pick up cheap. The kind of code that you describe (three letter groups at five words per minute, machine generated) will lend itself fairly well to the techniques that Alan described above with a caveat. The pool environment will likely give some fairly strong reflections of the original signal and a variety of other sounds as well. This will require some filtering so that the morse decoder will not be fooled. Since it is a repeating code, it shouldn't be too difficult. Good luck.
Al
WB9UVJ
www.wildstang.org
Unread 01-04-2008, 18:26
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We're planning on entering this competition again, and probably would just have the robot operator listening to the signal and trying to decode it. This would just have a mic and amp in the robot, and send the audio signal to the surface over a twisted pair or coax cable in the tether, and the driver would listen to the sound using the speaker built into the TV being used to watch the video signal from the robot.
I think the original poster is mainly trying to figure out how to send an audio signal from an analog input on the IFI RC back to the IFI OI, then use the Dashboard to hear it. I know nothing about the Dashboard....so I can't help...but maybe this will clarify the problem better for those trying to help?
I'm assuming the OP is planning on tethering the IFI OI and RC.
Unread 02-04-2008, 07:44
Unsung FIRST Hero
Rookie Year: 1996
Jim,
With a little thinnking that might be possible. The dashboard as I understand it just ports all the data that is streaming between the RC and OI out the dashboard port. Dave Flowerday might be able to lend a hand there. If you use the microphone to pick up audio that is filtered and then rectified you could use it to set a bit in OI stream. At the OI you could then use the bit to set an LED output that could fire an audio oscillator that would be a representation of the original audio and the code spacing. You wouldn't need the dashboard for that.
I don't believe the dashboard data would be fast enough to give you a digitized audio signal. Most code is between 500 and 1000 HZ with most operators comfortable at 700Hz. To be able to digitize in a simple fashion, you would want to be able to have data at about twice that rate to allow simple recovery (D to A) at the OI.
Al
WB9UVJ
www.wildstang.org
Unread 02-04-2008, 08:39
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
The IFI RC's A/Ds have a 10 bit resolution. That should be plenty for the quality of audio you are looking to use. After the RC has values from the A/D, it could conceivably transmit them as a byte and a couple bits on another byte, which you could write a LabView app to decode back into audio. I once wrote a fairly simple assembly program for a pair of 68HC11's to do exactly this. One chip used an A/D to get input from a mic, stored it to a memory system that I designed, and then transmitted it to the other processor, which used an R-2R ladder that I built to output out to a speaker. The amount of data required is very minimal, and I think that the system would be able to keep up, seeing as a good part of a kilobyte is sent per packet. Theres plenty of room to snag 10 bits. (as many as you want, really.)
Again, the question would be speed. If it's too slow, then you could have the RC keep track of two generations of data, and send them both at once (again, using twice as much bandwidth per cycle, but who cares? Theres plenty of room.)
You could even do that more than twice if the resolution isn't high enough. Play around with it.
Jacob
Unread 02-04-2008, 09:04
Software Architect
There's nowhere near enough bandwidth in the RC-OI data stream to pass general audio through the IFI radio modem. You could perhaps get sufficient processing power to do a chunky spectrum analysis and send a dozen or so samples per second, enough to make it possible to recognize a Morse code signal at the other end.
If the frequency of the signal is known in advance, I'd suggest detecting it in hardware and just relaying the output of the detector to the operator.
Microphone? Tim Arnold Programming 8 14-02-2008 07:53
This Weekend! - Delaware FIRST Vex Challenge & First State FIRST LEGO League Tourney Mr MOE General Forum 4 28-01-2007 07:59
**FIRST EMAIL**/FIRST Annual Fund Message from James R. Utaski, FIRST Board of Direct miketwalker FIRST E-Mail Blast Archive 0 27-05-2004 11:25
**FIRST EMAIL**/First Annual FIRST Robotics Conference, April 16 April 18, 2004 for t miketwalker FIRST E-Mail Blast Archive 6 04-04-2004 18:31
