Go to Post Finish... what an interesting concept. I'm still hoping to do that to our 2003 bot. - Joshua May [more]
  #16   Spotlight this post!
Unread 17-03-2008, 17:26
bobdahaxor's Avatar
bobdahaxor bobdahaxor is offline
Making the impossibe... possible
AKA: Andrew Lane
FRC #1727 (Dulaney robotics)
Team Role: Leadership
bobdahaxor is an unknown quantity at this point
Re: HELP!
I have some clarification questions and then an answer based on my assumptions (questions).
1. Can you turn the robot well when you are already moving?
Better, but not amazingly
2. Does the problem only happen when you are sitting still and you want to turn without moving forward first?
more or less yes
3. do you have the wheels on one side go in reverse when turning or are you trying to turn with just one drive wheel? (see our experience below for why I ask this question).
one is in reverse and one is going forwards
REX 1727
2008
Chesapeake Regional - Gracious Professionalism Award
Philadelphia Regional - Best Website Award
2007
Chesapeake Regional - Chairman's Award
Chesapeake Regional - Industrial Safety Award
Trenton Regional - Kleiner Perkins Caufield and Byers Entrepenuership Award
2006
Chesapeake Regional - Highest Rookie Seed
Pittsburgh Regional - Rookie All-Star Award
Pittsburgh Regional - Best Website Award
www.dulaneyrobotics.com
  #17   Spotlight this post!
Unread 17-03-2008, 17:57
ll4m4ra0r ll4m4ra0r is offline
AKA: Patrick
FRC #1727 (Rex)
Rookie Year: 2007
ll4m4ra0r is an unknown quantity at this point
Re: HELP!
To all you non-believers :
We drove around for a few solid 30-minute intervals with the drive on linoleum. (After each time the drive was very hot though. ) Granted, it's not carpet, but hey, when it was working, it didn't have overheating problems after a match. We went to, and performed very well at, a "playdate" the Saturday before ship date on the NASA-Goddard field, and the drive worked beautifully (until we had an issue with bending an omni on a plate). So that leads me to believe very strongly that there is not a fundamental design problem so much as a newly-acquired mechanical problem.
  #18   Spotlight this post!
Unread 17-03-2008, 18:00
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: HELP!
Problem #1: non-carpeted surface in testing, and your motors are very hot. There's something there that just doesn't sound right, even though you carpet tested on the Goddard field. I think it is a design problem.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
  #19   Spotlight this post!
Unread 17-03-2008, 18:07
AKA: Patrick
FRC #1727 (Rex)
Rookie Year: 2007
Re: HELP!
The issue we have is, why did it work on the NASA field, but not at the regional? The only thing i saw different was the dry transmissions, so that's my only guess.
  #20   Spotlight this post!
Unread 17-03-2008, 18:16
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: HELP!
Another thing to look at (in addition to every thing else already said):
We used the banebots transmissions last year (12:1 direct drive). We had a different drive setup with 4 driven mec wheels. However, one of the wheels would catch intermittently. We couldn't replicate the problem in the pits, but eventually discovered that the sticky wheel was ever so slightly out of alignment, causing the planetary gears to stick.
I'm not sure if this is applicable to your banebots transmissions since they have made some design improvements from last year, but they are sensitive to side loading. It could be that during turns you are adding enough twist to the frame that it is causing binding in the transmissions due to an introduced side load on the drive shaft.
  #21   Spotlight this post!
Unread 17-03-2008, 18:31
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: HELP!
I disagree. Our drive system found here puts more side load on the transmissions then most drive systems will. and with three weeks of driving (on carpet) we still have no problems what-so-ever (knock on wood )
It seems to me the transmissions being dry may be the biggest problem.
Secondly, can you turn the traction wheels by hand? (you should be able to, we can) If you can't maybe its the way you mounted the wheels?? I haven't seen wheels mounted that way before(not saying its bad, its just different for me) and may cause a "brake pad" effect... although you said no problems with driving striaght... how well can you drive backwards?? if you are turning like normal skid steering, then maybe thats what is cause the problem.
Hope it gets fixed and good luck!
  #22   Spotlight this post!
AKA: Patrick
FRC #1727 (Rex)
Rookie Year: 2007
Re: HELP!
Do you mean the wheels would push the transmissions to the point of binding?
  #23   Spotlight this post!
Unread 17-03-2008, 18:35
AKA: Patrick
FRC #1727 (Rex)
Rookie Year: 2007
Re: HELP!
It should be noted that the omnis also spin freely, and all the rollers spin freely as well.
The wheels can be turned fairly easily, but we avoid forcing the wheels to prevent damage to the electronics On second thought, we never tried spinning the ungreased transmissions. Thanks, as soon as we get our hands on our robot were gonna try some greased up transmissions.
  #24   Spotlight this post!
Unread 17-03-2008, 19:11
FRC #1360
Re: HELP!
unplug from electronics
  #25   Spotlight this post!
Unread 17-03-2008, 21:38
AKA: Dan
Re: HELP!
That is correct, but it only happened to one of our transmissions. It could be that the newer transmissions can accomodate the side load better, though, so make sure you try all the suggestions possible here. Hopefully you can solve it easily with some grease, rather than a complete redesign.
  #26   Spotlight this post!
Unread 17-03-2008, 22:04
AKA: Patrick
FRC #1727 (Rex)
Rookie Year: 2007
Re: HELP!
Crossed fingers. I've seen other teams use 2 cim drives with the same setup, and it worked fine, so it can't be design problems only.
  #27   Spotlight this post!
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Re: HELP!
more or less yes
Thanks for the clarifying questions; they help provide some clues as to what is actually going on.
One of the issues with a 2WD system is the issue that was pointed out by dtengineering in his post -- you want as much of the weight to be on the driven wheels (in your case, the IFI traction wheels) as possible, with as little weight as possible on the undriven wheels (the omni wheels).
When the robot fails to "spin in place" when you drive one wheel forwards and one in reverse, which of the following happens? (1) The traction wheels spin on the carpet, with one going forwards and one going backwards, or (2) the motors are stalled out, trying to rotate, but nothing is moving at all, the wheels aren't even spinning.
If the problem is case (1) with the spinning wheels, you should be able to resolve the problem by moving heavy components from the omni-wheel end of the robot to the traction-wheel end of the robot. In particular, the compressor and battery are two excellent candidates for this. I suspect that this scenario is the problem that you are experiencing. Any weight you can move from over the omniwheels to over the traction wheels helps in two ways: (a) by reducing the resistance to turning since there is less weight on the undriven wheels and (b) increasing the traction available to the drive wheels by increasing the weight on those wheels. If the wheels are spinning due to a lack of traction, no gear ratio changes will be able to fix the problem.
The other possibility is case (2) with the traction wheels being stalled out. I would be amazed if this is the problem, as there is actually quite a lot of torque available in your transmission setup. If this is happening, it is almost surely due to your omni wheels not sliding sideways readily, either because they are somehow getting caught on the carpet, or the rollers are not spinning easily. Another possible root cause if you are seeing this problem would be binding of the transmission mechanism.
As for the single CIM drive mechanism potentially having insufficient power, our team's hurdling base used a single CIM drive on each side, with a final ratio of about 19:1, but using 12.5" wheels, giving almost exactly the same peak travel speed (and thus the same torque, since we are using the same motors) as your configuration. We had no troubles turning, but we had the weight of the robot very nearly centered over the drive wheels. This configuration still had excellent acceleration, even though it wouldn't win many pushing matches.
I believe that moving weight from the rear (the omni end) of the robot to the front (the traction wheel end) will probably solve your turning problem. However, it will also introduce another problem that your drivers will need to deal with... When the weight is largely over the front driven wheels and you then are traveling forward at full speed and suddenly apply full reverse power, the robot will have a big tendency to tip over forwards. Just something to watch out for...
Please let us all know what you end up doing to fix the problem.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
  #28   Spotlight this post!
Unread 31-03-2008, 14:59
AKA: Patrick
FRC #1727 (Rex)
Rookie Year: 2007
Re: HELP!
Thanks for all your input everyone! We initially replaced the omnis with Andy Mark Coolie Dualie wheels, and shifted the battery forwards. We still had issues with overheating and not being able to turn, and resorted to replacing the 12:1 transmissions with 16:1 transmissions. This solved our issues, and surprisingly, there was almost no noticeable speed decrease. The cims would be at around 10 degrees above ambient temperature after every match, and we could turn fine. In the end, there was just not enough torque with the 12:1 transmissions, and it just couldn't turn.
After we fixed the drive, we went on to be quite effective at Philadelphia, and we are looking forward to Atlanta!
Grab Frame - Help Help Help... nmihailidis Programming 2 04-03-2007 14:44
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
