Slow Program Loading
Hi,
I've been working with easyC for a few months and just watched the video about programming for FRC. His unit seems to load a program in mere seconds, whereas my unit seems to take ~45 seconds. Is this a hardware issue? Also, it seems not all variables function in my program. I have only managed to get "int" to work, anything else will cause the program to not function. What is wrong? |
Re: Slow Program Loading
Are you using a USB to Serial Adapter?
Yessir.
Program loading is much slower when using a USB to serial conversion cable. The conversion, evidently, introduces a bottleneck in the process. As far as your program problems go, you should try posting your code so people can try and figure it out for you.
If you have a computer with a real serial port and connect the programmer it will program much faster.
I concur - the USB Serial adaptors (we have several) always load 2-4 times slower from the laptop. When the 'real' serial port on our tower PC is used, download takes less than 10 seconds.
| CPU easily maxes out in WinXp Pro, IE slow loading | sanddrag | IT / Communications | 32 | 12-08-2006 02:38 |
| help with program loading | psych0gambit | Programming | 2 | 17-02-2005 19:03 |
| How slow is too slow? | Joe Ross | Rules/Strategy | 23 | 12-10-2004 20:23 |
| Loading Program to Controller.....problems | Wbrown0389 | Programming | 5 | 27-02-2004 17:14 |
| Slow day? | Josh Hambright | Chit-Chat | 6 | 06-04-2003 00:28 |
