Lap Counter IR Interference?
What technology is used for the lap counter. IR? I heard this is true. If this is the case, it could interfere with the robot's IR board and Robocoaching efforts. Has this happened at other regional competitions?
Thanks, LR |
Re: Lap Counter IR Interference?
Team 25 seemed to have problems with it.
It is also one of the many things I suspect in our IR difficulties at FLR. We got it working, but I have not isolated the problem. Other possibilities include: abrupt power up of the sensor when it was attached to a spike and extra interference on the Blue side (always worked on Red side, never on Blue). Our IR board works flawlessly when not on the field. At Philly I should be able to isolate the problem. Last edited by The Lucas : 17-03-2008 at 16:01. |
A tiny bit more information is provided in FIRST's Team Update 14. (See the second section within "General Notices" on the first page, entitled Mounting your IR receiver.) |
Place your IR receiver below the lapcounter, and use something
to shield it from IR light bouncing down (off the overpass metal) from above. Eugene |
Thank you all for the good info. I even managed to find a photo of an installed IR transmitter. I will take this into account when we mount the IR Detector.
LR |
We were having some problems with it while waiting in the queuing line. Our programmers took notice that our IR board was getting a signal (one believed it was even to the beat of the music).
But our flag and IR board were at about the same level. We did check the surrounding area to see if anyone was spamming IR signals (don't know why they would) and our results were inconclusive. Didn't matter though, they took out the code because our dead reckoning got us 3 lines 95% of the time anyway, and the IR board was just going to stop the robot if it got out of control. |
| Lap Counter Wieght | Pelicano234 | Technical Discussion | 4 | 20-02-2008 09:45 |
| Lap counter, What port? Mounting Rule 18 | ericsundbergva | Technical Discussion | 11 | 19-02-2008 08:22 |
| Lap Counter??? | RoboGeek99 | Technical Discussion | 3 | 25-01-2008 19:33 |
| So uh yeah... How 'bout that lap counter? Also Metallica. | Tach'ko | Electrical | 11 | 21-01-2008 12:01 |
| pic: IR Lap Counter on the Manchester Kickoff Field | ahecht | Extra Discussion | 13 | 06-01-2008 21:38 |
