Legality of Team 190's Mechanism?
This thread is not meant in any way to take away from the creativity of team 190. I personally think it is in theory, one of the coolest ideas I've seen this year. However, I just thought I'd bring this Q&A answer up to share.
http://forums.usfirst.org/showthread.php?t=9187 Does this mean that Team 190's hurdling mechanism is illegal? |
Re: Legality of Team 190's Mechanism?
can we see a pic of what you are talking about?
I have no pictures of it in action, but perhaps this would be helpful?
http://www.thebluealliance.net/tbatv/team.php?team=190 Edit: Qualifcation match 45, approximately 55 seconds, but it should continue all the way around and released on the other side of the red overpass for a hurdle. Last edited by SU 39 : 17-03-2008 at 20:57. |
Now that the GDC has responded, 190's entire strategy has been declared illegal. At least one other team has the same problem, if the Q&As are anything to go by.
The response indicated is a reversal of this Q&A. I just hope 190 is done competing for the year. Unfortunately, I don't think they are. |
It seems to me that having part of the robot in Quadrant 4 before ever leaving Quadrant 1 is a technical violation of <R22>, exactly the same as if you drove from Q1 partly into Q4 during the match.
In my most humble opinion, it just looks like that 190 did some very good research and found a legal way, call it a loop hole if you must, to play AND conquer this game..... Kudos from me...... I'm sure there is questioning out there, but why would a veteran team try and find a shortcut. They've already proven in the past several years they are very capable team..... I see no need for them to be questioned........ By the way how's the ankle Ken?
Mike |
Originally the rules were written in a way that 190 and many other hurdlings mechanisms would not complete valid hurdles (by most interpretations) since they were contacting the ball while crossing the finish line. Then I think there was a short time period where the interpretation was a bot could contact the ball while it was crossing, but not crossed the line. Now, a bot can continue to contact the ball while it has crossed the finish line as long as the bot hasn't crossed the finish line. Personally I like the hurdling interpretation where as you can contact the ball while it is crossing, but not crossed the finish line. I mean we are "hurdling" not "stepping over" ![]() |
Well, looking at the robot on the video, it pretty clearly violates G22. Considering the discussion around G22 here on CD and in the Q&A forums, I am surprised this was not apparent to the team when they designed their robot. This is quite a different case than the "two robots" or "one robot" issue, where the team complied with all the rules and Q&A as they were written, but then were arbitrarily declared in non-compliance at the competition. It is ironic that in this case the team was given an award for their design, but 1519 was not.
However I believe there may be a way for this design to comply with G22. G22 states that the robot must break the plane in a clockwise direction. Would it be possible to build an extra appendage on to the end of the arm, such that the appendage rotates (assuming the home stretch is q1) from q2 into q3, and then back into the home stretch in a clockwise direction. I can't really show that here easily, but I'm sure someone with sufficient motivation could figure out what I am talking about. OR the team could, on their first pass around, take a penalty, but drop a small part of the robot, attached by a cord, into each quadrant. At this point the robot would be in all four quadrants at the same time, and should no longer be subject to penalties. I know, I know... this probably falls into the "lawyering" the rules concept.. at least the second suggestion does... the first one strikes me as being in keeping with both the wording and intent of the rules, but I do have some sympathy for the team, who probably never thought they were violating G22 when they designed this.... even though I think it is pretty clear that with their present set up, they do. Jason |
#10
Intentionally committing penalties may cause you to receive a yellow card. Last edited by jgannon : 17-03-2008 at 23:07. |
#11
What I had in mind for the first suggestion was something like the rather quick sketch I have attached here. Again, it might not be really in keeping with the spirit of the rules, given that there is a rule that pretty clearly states that robots are to proceed about the track in a counter-clockwise direction... and in this case the robot will not be "proceeding" but throwing some ideas out there is about all I can do to try and help 190 right now. Jason Edit: note comment below regarding diagram. Last edited by dtengineering : 18-03-2008 at 00:11. |
#12
Do they really have to take a penalty? If before the leave the very first quadrant (the one they start in) they place a small four-legged object atop the lane divider (one leg in each quadrant); and then operate with the bulk of their robot remaining in that original quadrant for the rest of the game; does that allow them to be in all four quadrants at once without ever returning to a quadrant that they left sometime in the past, without ever exceeding the height limit and without ever posing an entanglement risk?
#14
It's definitely good that you're helping them brainstorm. The one bit that I keep getting hung up on is how to get the ball across the line from Q3 to Q4 and back to the robot without putting any part of the robot into Q4. How does the ball play into all this?
| pic: Team 1178 Robot - Hand mechanism | Jake M | Robot Showcase | 0 | 01-03-2007 19:41 |
| Introducing 190's Gompei the Burninator | ahecht | Robot Showcase | 7 | 22-02-2005 23:55 |
| pic: Introducing 190's M.O.H. Goat | CD47-Bot | Robot Showcase | 24 | 01-03-2004 00:53 |
| pic: Team 60 Mechanism | CD47-Bot | Robot Showcase | 2 | 11-02-2004 21:47 |
