Go to Post I have long since stop trying to predict what the GDC will do. - FrankJ [more]
Unread 18-03-2008, 11:56
mole mole is offline
AKA: Anmol Dhar
FRC #0772 (SabreBytes)
mole is an unknown quantity at this point
Wireless Robot Interface
Hey everyone,
I was wondering if anyone knew how to receive and input information to/from the robot wirelessly using a laptop?? I am planning to make a interface allowing the driver to communicate with the robot and so they can receive information about the status of the robot. (battery lvl, heat of motors...)
Thanks
Unread 18-03-2008, 12:13
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: Wireless Robot Interface
Use the dashboard port on the OI. This is the only legal method at competition.
and it can only be used for output. Robot can only receive input from switches and stuff attached to the OI
Unread 18-03-2008, 12:46
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
For development at your own facility, the simplest solution would be a Bluetooth serial link. See http://www.blueconsole.com/ for one option.
At a FIRST competition, the rules currently prohibit any wireless communication to/from the robot other than the provided radios. There's no practical way to send data from a laptop, but you can receive from the robot using the dashboard port. You've got six bytes of user data in the dashboard stream to work with, and you can "borrow" unused PWM outputs for telemetry information as well. The battery voltage is already provided in the dashboard data.
Unread 18-03-2008, 14:39
programMORT11
Posts: n/a
We wrote a gui in python this year to display information about the robot (wheel direction, end effector height, etc.) and the best way was to use the dashboard port on the OI to send back serial packet data
Unread 18-03-2008, 15:23
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Rookie Year: 1997
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
How well does this work? Does it allow for debugging of data while the robot is running? This would make programming significantly easier!
Also, do you know of anyplace you can purchase these? The site says they are no longer selling them.
Thanks!
2010-? - AIR Strike (Team #78)
2007-2009- Rhode Warriors (Team #121)
2003 - Team #190
1997-2002 - Bobcat Robotics (Team #177)
http://www.tomschindler.net
http://www.drivexc.com
Unread 18-03-2008, 15:25
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Thanks!
www.sparkfun.com
I'm sure you can find other places as well.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 18-03-2008, 15:35
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
http://www.amazon.com/Bluetooth-Seri.../dp/B000CPMBO6
Unread 27-05-2008, 20:04
AKA: Anmol Dhar
Robot Interface
Our team is trying to mount some different types of sensors to give us basic data about the robot's condition during the match. The information would be sent through the OI into a display.
Do you think this is possible?
Unread 28-05-2008, 00:14
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: Robot Interface
Are you looking to have the information on the laptop or on another form of screen? Also is this something you are looking to do next year or is this an off season project? Depending on what exactly you are looking to do, much of the dashboard program (using the dashboard port via serial cable) will give you values to items you want to read, you would just have to set this in code.
-Mike
Unread 29-05-2008, 21:53
AKA: Anmol Dhar
this is for next year and for the off-season. We were planning to have it displayed on some sort of screen or a laptop it doesnt matter.
Unread 24-04-2009, 20:10
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
I created an embedded web server that you can run on the bot. You can use it to display/modify any variables that you want. C++ only.
http://www.chiefdelphi.com/forums/sh...ad.php?t=76928
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
BASIC operator interface and robot controller John Gutmann Electrical 2 26-04-2005 21:45
2003 robot controller & interface LGuY Control System 3 04-04-2004 16:01
Failure of Robot Interface Matt McNelley Technical Discussion 23 08-04-2003 21:32
Robot Controller & Operator Interface troubles patrickrd Technical Discussion 10 25-10-2001 07:36
