Help: wiring ADXRS300EB Gyro Eval Boards
Just got our Eval board from Digikey.
I presume I wire red to AVCC, Black to AGND, & white to RATEOUT. But the documentation says " Note the... charge pump supply ... PDD.. are not connected on the ADXR... and the user must connect these as appropriate. What do I do with PDD ? connect it to red as well ? |
| ADXRS300EB gyro help | Chris Bright | Programming | 4 | 08-02-2005 17:59 |
| 2003 Gyro Wiring Harness | DukesAZ | Electrical | 3 | 03-02-2005 18:20 |
| 2003 Gyro Wiring Harness | DukesAZ | Technical Discussion | 3 | 03-02-2005 18:20 |
| ADXRS300EB Rate Gyro | rmeenaks | Electrical | 18 | 05-04-2004 22:37 |
| ADXRS300EB Rate Gyro | rmeenaks | Technical Discussion | 0 | 31-03-2004 16:48 |
