Go to Post So we get to hear the likes of Copioli, Baker and Patton yuk it up? This should be good. - Ricky Q. [more]
Unread 18-03-2008, 22:55
CuriousGeorge CuriousGeorge is offline
CuriousGeorge is an unknown quantity at this point
Exclamation how does one go about making a 6 wheel config drivetrain?
i am very curious to know, and would like to make one. please any details would be awesome, as well as pictures... please!
Unread 18-03-2008, 23:07
EricVicenti EricVicenti is offline
FRC #0008 (Paly Robotics)
EricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura about
Re: how does one go about making a 6 wheel config drivetrain?
There are many different elements required for a 6 wheel drivetrain, so to get a better idea where you are coming from, could you describe the type of drivetrain you are used to?
Essentially, the basic concept behind a 6 wheel drive is that the middle wheels are lowered, so you are only driving on 4 wheels at a time, which will reduce scrubbing immensely while turning. If your robot is balanced well, the front and back wheels will lift off the ground while turning, and only your middle wheels will be in contact with the ground.
Unread 18-03-2008, 23:15
mainly, im thinking of getting out of anything im used to, for me it just doesnt seem to be working.
i want a fast and speedy drivetrain with the power of a tank. 25 seems to do that well.
Unread 18-03-2008, 23:18
Well what exactly are you used to?
4 wheel, wide drive? Ackerman?
Unread 18-03-2008, 23:20
4 wheel
Unread 18-03-2008, 23:32
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
We had 4 wheel up to 2004 when we got tired of the robots tripping breakers and dancing around. Since then we've been using 6WD with the lowered center wheel. There are many pictures on our website: http://www.teamfusion364.org/Photos%20main%20page.htm)
Look at the build season photos, primarily week 1 and 2 for our drive train.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 18-03-2008, 23:43
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
Rookie Year: 2007
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
kitbot would be a good place to start, just chain your wheels together on each side (you'll probably drive the middle wheels and run chain from there to both the front and the back)
if you're feeling ambitious, you could replace the kitbot angles with 1/8th wall 2x1 or 3x1 aluminum box beam... I can post some pics of our drivetrains if you want them.
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
Unread 18-03-2008, 23:56
would love some pics
Unread 19-03-2008, 00:40
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I found some pictures of 330's 6WD drop-center drive that somewhat show the chain routing.
http://www.chiefdelphi.com/media/photos/23376
http://www.chiefdelphi.com/media/photos/27675
http://www.chiefdelphi.com/media/photos/30206
Their chain run goes like this: Trannies to center wheel and rear wheel. Center wheel has another chain, which runs to the front wheel.
Just a note, the drive's various iterations have won 3 regional wins, 2 regional finalists, 1 world championship, and 2 divisional wins, with one regional left for the team to play in 2008, just on 330.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 19-03-2008, 00:57
Many teams choose to use #35 chain, but in my experience, it is way more bulky and heavy than necessary. Team 8 uses #25 chain. Keep in mind that tensioning is very important. The two ways of tensioning are to pull the wheels back, or to push the chain down, either with an idler sprocket, or some other material that wont wear out, such as HDPE.
Also, most teams don't directly drive any wheels with 6wd, which isn't a bad choice, but in terms of simplicity, we choose to drive the center wheels, and to have 2 chains run to the front and back. This year, we originally designed our drivetrain to use AM super shifters. When we found ourselves nearly overweight, we decided to make our own gearboxes from the toughboxes and the supershifters, so we ended up with non shifting gearboxes, 8:1 ratio (fairly high, higher than either the toughboxes or the supershifters), the size of toughboxes with the mounting pattern of supershifters.
Unread 19-03-2008, 01:08
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Some teams won't touch #25 in the drive with the length of the overpass. They say it's too weak. It isn't, but if not done right, it can be. (The last time 330 used #25 on a robot was the second stage of their shooter wheel drive in 2006 going to the wheel. It was the first time since 2001, when contact was minimal and #25 was used in the drive. Later, we had a lot of problems with drive chains jumping while using 2001 as a practice bot.)
Past teams:
Unread 18-03-2008, 23:41
so how far would the middle wheels be lowered? 1/4 inch?
Unread 18-03-2008, 23:44
danshaffer's Avatar
Stanford 2012
Rookie Year: 2007
1/8" is all you really need...
Unread 18-03-2008, 23:47
any pictures to help furthur my options or help me in any way would be most helpful and def accepted. i really thank you u all for helping me with this much info so far
  #15   Spotlight this post!
Unread 19-03-2008, 00:54
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Well, the simplest way is the KOP frame. If using KOP wheels (you'll need 6 of them obviously). Put four at the ends like you normally would. There is a hole that is slightly lowered in the center of the frame that you should use for your middle wheel.
It is lowered to relieve the pressure from the corner wheels so you can turn easier.
The easiest way to run chain is with the center wheel having two sprockets and the ends having 1.
http://andyburchardt.com/robotics_re...0Drive%201.jpg
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
1519 - One Dual-Config Robot or Two Robots? Ken Streeter General Forum 127 12-03-2008 15:26
What do you think about how easy theyre making programming? Leav Programming 76 11-01-2005 12:07
How does one become a ref? minic@HYPER69 General Forum 11 05-05-2004 01:08
How does one go about ordering more motors... Team852 General Forum 3 27-01-2003 14:37
How Do I Program My RC To Spot One wheel From Going faster than the other Kyle1010 Programming 5 12-01-2003 15:30
