Go to Post This has to be the hardest, most complicated game I've ever seen the GDC develop - that's what makes it so much fun! - SteveGPage [more]
Unread 19-03-2008, 11:29
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Intelitek CNC Motion - Virtual CNC Machines
CNCMotion integrates interactive 3D simulation with CNCBase machine control software for dynamic simulation and graphic tracking of Intelitek's CNC mills, lathes and router.
CNCMotion simulates the entire machining process in real time-accurately reflecting the movement of machine components and tools, and the form of raw materials changing into finished parts.
The virtual machines in CNCMotion respond to errors and environmental conditions in the same way as safeguards on real machines prevent injury and damage. Safety measures include halting NC program execution upon impact or axis limit, and warnings of unsafe hardware conditions (e.g., safety shield open, tool missing, tool impact on the cross-slide or holding device).
As a powerful visualization tool, the software enables testing and debugging of programming, as well as full machine setup, prior to actual CNC machining and turning.
The simulation includes fixturing with all available Intelitek hardware options. For example, simulated stockholding options for the Super proLIGHT 1000 machining center include a 52-piece hold-down set, machinist vise, low profile clamping kit and two air vises. Simulated tooling options for the Super proLIGHT 1000 include flat end mills, ball end mills and drills, along with R-8 tooling, quick-change tooling, and automatic tool changing (ATC).
The realistically simulated CNC machines give students and machine operators valuable experience before they begin working in a CNC workshop.
Download a Demo of CNC Motion
Note: When Installing Select "CNC Motion for Super Prolight" and Select "Default Setup" for Machine Serial Number
For a demonstration or additional information please contact Intelitek Sales at 800-221-2763.
CNC 3D printer sciencenerd Technical Discussion 5 06-08-2007 13:32
CNC Machines DEAL234 Technical Discussion 17 07-02-2007 16:30
What machines are you using? (CNC, lathes, mills, 3-in-1 machines?) MrB Technical Discussion 17 03-11-2006 11:55
Help - G-Code Circular Motion for CNC Milling sanddrag Technical Discussion 15 18-08-2004 23:00
To CNC? Or not to CNC? phrontist General Forum 21 26-03-2004 13:45
