Go to Post It's funny how many things learnt in Physics class at school I am able to apply to FRC. - pilleya [more]
Unread 24-03-2008, 11:32
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Intelitek - CNC Milling Machies
For a demonstration or additional information please contact Intelitek Sales at 800-221-2763.
Benchman MX
The new Benchman MX has the flexibility to be the perfect benchtop CNC machining center for your shop floor. Based on an advanced modular concept, this machine lets you select the exact features and options that will meet the critical needs of your applications.
Build the machine you need for the jobs you want done.
When you need a solution with the perfect combination of features, finding an affordable tool that meets all your requirements can sometimes be a real challenge.
The new Benchman MX has the flexibility to be the perfect benchtop CNC machining center for your shop floor. Based on an advanced modular concept, this machine lets you select the exact features and options needed to meet the critical needs of your applications. No more, no less.
With its unrivaled selection of configurations, the Benchman MX is the solution. It's what you make it.
With its unmatched scalability, the Benchman MX gives you exactly the capabilities you need.
And you always be able to add features when your demands change.
Super proLIGHT 1000
A versatile 3-axis CNC mill for training, engineering and light-duty industrial machining applications. Designed to produce accurate machining and smooth surface finishes. R8 spindle taper accommodates standard tooling.
The Super proLIGHT Machining Center uses the latest innovative technology in its design to meet the challenges of today's students. Using a vibration-dampening polymer composite in its one-piece base and vertical column it is able to machine most materials, including steel.
The Super proLIGHT 1000 Machining Center is a bench top state-of-the-art CNC machining center. It uses EIA, ISO and Fanuc-compatible G&M codes, as do larger CNC machines. It is a full three-axis (optional rotary-axis) machining center with an ISO tool holder spindle.
Features include: Manual iso quick-change tool holders or a four-tool station automatic tool changer. Linear, circular and helical interpolation, multiple-tool programming, canned cycles and cutter tool compensation are just a few of the programming modes the machine's software supports.
The Super proLIGHT Machining Center is used at the Skills USA VICA national competition in the Automated Manufacturing Technology competition.
eXpertMill VMC-0600
The eXpertMill VMC-0600 is the newest in Intelitek's line of benchtop CNC training and industrial prototyping machines.
Key design features include a cast aluminum base and profile linear guide ways that provide the rigidity, speed and accuracy of larger industrial machines.
The eXpertMill offers simultaneous three- or four-axis machining along with features and options usually found only on full-scale machining centers. Full three-axis tool path verification, standard EIA RS-274-D G&M code programming, 1 hp spindle power, and 100 ipm (2540 mm/min) rapid traverse and machine cutting rate make the eXpertMill the ultimate machine for CNC training and prototyping.
Optional features include a 200 ipm (5080 mm/min) high performance controller, 4- and 12-position automatic tool changers, and a 4th axis rotary positioner.
spectraLIGHT 0200
A tabletop CNC system that fits comfortably into any classroom. This 3- axis machine uses EIA, ISO and Fanuc compatible G and M code programs to cut parts in a variety of materials.
The spectraLIGHT 0200 Machining Center is a desktop portable state-of-the-art CNC system that fits comfortably into the classroom. Similar to larger industrial machines, the spectraLIGHT Machining Center uses EIA, ISO, and Fanuc-compatible G&M code programs to cut parts in a variety of materials. Linear, circular, and helical interpolation, multiple tool programming, and canned cycles are just a few of the programming modes the machine's software supports.
For thousands of schools worldwide - from middle schools to universities - the spectraLIGHT is the system of choice, whether introducing students to the fundamentals of manufacturing or preparing them for challenging careers in engineering, manufacturing, and industrial technology.
Intelitek Mechatronics Curriculum Kingofl337 Programming 0 19-03-2008 17:06
Intelitek CNC Motion - Virtual CNC Machines Kingofl337 Programming 0 19-03-2008 11:29
Intelitek Learning Management System Kingofl337 Programming 0 19-03-2008 11:21
To CNC? Or not to CNC? phrontist General Forum 21 26-03-2004 13:45
