udata_Tx.o cannot fit the section. help needed
Hi...
Am new to RTRT and PIC... In verification stage, when i try to build a file (x.ptu for the source file x.c, using Rational Test Real Time), the following error is encountered.. Error -section. 'udata_Tx.o' can not fit the section. Section '.udata_tx.o' length=0x00001368 Environment: Controller used is PIC18f4620 and MPLAB IDE v7.50 RTRT(Rational Test Real Time ) v7.0 Pls help me to get through this... Thanks in advance... Kumar. |
| complie error can not fit the section. Section xxxx | Doug Leppard | Programming | 5 | 12-02-2008 09:44 |
| MATH_DATA can not fit the section | neutrino15 | Programming | 7 | 03-02-2008 21:04 |
| Error - section 'UTIL_LIB' can not fit the section. Section 'UTIL_LIB' length=0x00000 | BookerT | Programming | 13 | 27-01-2005 09:49 |
| Error - section 'UTIL_LIB' can not fit the section. Section 'UTIL_LIB' length=0x00000 | BookerT | Programming | 0 | 25-01-2005 19:17 |
| Linking Errors: "section '????' can not fit the section. ..." | Astronouth7303 | Programming | 3 | 16-01-2005 21:36 |
