Go to Post Unlike robot design, in the clothing world there's no such thing as too much pocketing - Jaci [more]
Unread 25-03-2008, 14:29
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Angry Too many (If, Else If) statements?
Hey all!
I've been trying to make a better autonomous before our next regional. Since it's a day away, i've started to panic even more!
I've been using Kevin Watson's IR code, with a few additions to take commands and store them into the EEPROM. Once the commands are stored in the EEPROM, I have about 10 If/Else If statements to give our autonomous routine its desired waypoints.
Once I loaded my code via IFI Loader, the program light was STILL blinking! My code never entered the user teleoperated routine.
Later, I tried removing a few of the If/Else If statements, and I was left to TWO If/Else If statements. I compiled and loaded the code, the robot entered the user teleoperated routine with no problem.
Could I be edging on the side of overloading our IFI RC? Is there a way to get around this issue?
Thank you in advance!
Unread 25-03-2008, 14:46
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Too many (If, Else If) statements?
This somewhat depends on where you put the if-else statements and if you had them all properly scoped. If you're putting these in an interrupt service routine, then it might just be taking up too much time and you'd get a red light of death. If you're doing this elsewhere then timing shouldn't be an issue. You might instead have some misplaced braces that are causing you to skip past the PutData() command or something. C18 doesn't seem to do anything too stupid when compiling nested if-elses, so I'm unsure what else this might be unless your code is so long that it needs to be using the large code model and you're not using it at the moment. Perhaps if you just tried re-compiling your original code. I can't think of anything other than a corrupted file that would keep the controller in a program state after a download.
Unread 25-03-2008, 14:47
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Is it using the large code model (see here: http://www.ifirobotics.com/docs/memory_problem_8722.pdf)?
Unread 25-03-2008, 15:04
kiettyyyy's Avatar
I went ahead and looked at my project files, the compiler was set to work with the small code model that was less than 64k bytes. I hope this works!! I'll be heading over to the field very shortly to find out.
Thank you!
Unread 25-03-2008, 17:38
kiettyyyy's Avatar
Thanks all!!! The code works great!!!
Too many interrupts? windell747 Programming 4 06-02-2008 23:55
pic: TOO MANY TETRAS!!!! Ali Ahmed Extra Discussion 12 22-01-2005 10:06
Else Statements!!! Adam Shapiro Programming 9 22-12-2002 01:27
