Go to Post Remember, however, that such software limitations in no way approximate the functionality of a multiple-speed, mechanical transmission. They're simply a convenient way of limiting your students' lead feet. - Madison [more]
Unread 25-03-2008, 22:29
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
Re: Pre-match Checklist
We use one adapted to the robot for each year. Biggies this year are to check that the battery is fresh and ziptied in, the air valve is shut, hybrid mode switches are set to correct position, driver 2 has control board and tether cable, robocoach has remote, etc.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 25-03-2008, 22:55
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by Tomasz Bania View Post
We instituted a mental checklist...
The whole point of a checklist is that it is not stored in someone's head. Relying on the pit and drive crews to remember everything is risky, especially if what they need to remember is more than about five or six things.
One copy of our robot's "preflight" list is affixed to the inside of the robot. It steps through a full functional test of all motors, pressure regulators, pneumatic actuators, and sensors.
Unread 25-03-2008, 22:56
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
We have a set of systems checks the drive team, mentors and pit crew run through after each match, as well as a list of things the drive team needs each time it goes to the field. We also have a safety checklist that drive team members know to follow after the matches to make sure no one gets hurt. Stored energy means safety procedures are mandatory.
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 25-03-2008, 23:04
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
We do a full check before leaving the pit, and then have a written list we use in the staging area and on the field for placement. To be sure we don's lose it, it is written on the top of my left hand, with a sharpie*. This way it won't get lost or forgotten.
The 2008 list includes:
New Battery (s)
Battery zip-tied
Back-Up Battery zip-tied
Pneumatic bleed closed
Pneumatic air pressure over 100 psi
Hybrid Mode Set
Robot ON
IR sensor ON
* which i am sure will be determined later in my life to be causing some disease
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 26-03-2008, 09:06
BigJ BigJ is offline
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 2007
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
1675 does their check in the pit just before queuing.
It includes (I'm going off of memory here)
  • Battery Check
    • New battery
    • Battery secured
  • Pneumatics Check
    • Check pressure and all that jazz.
  • Electrical Check
    • Check IO connections(PWMs/Relays/Digitals/etc.)
    • Tighten connections in distribution block
  • Controls/Code Check
    • Reload working version of code, EVEN IF you are 150% sure you didn't work on it since last match.
    • Test drive control
    • Test manipulator control (if safe)
  • Drivers Check
    • Are they here???
    • Do they have their screwdriver? (more on this later)
  • Mechanical Check
    • Tighten any crucial nuts/bolts/screws/things
Yeah, since our fiasco at the Quarterfinals of Midwest, our drivers carry a screwdriver for the distribution block with them, just in case.
(PS: ooh, nested bulleted lists!)
Unread 26-03-2008, 16:08
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Rookie Year: 2007
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
We used a checklist, but it wasn't enough to keep or robot in maintained for the semi-finals, where the electrical wires to the "Farm" (lego like thingy) got disconnected without us noticing.
Tip for teams:
Make sure your sub-teams go over ALL the possible problems that can occur on the robot (try and improvise if you need to) and find the solution to those problems. Gather these together, see what is common and what is not, and let a pit crew member to be responsible to check the robot 5 minutes before you're called to the next match.
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 26-03-2008, 16:27
Schnabel's Avatar
Schnabel Schnabel is online now
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
We made a preflight checklist, but we started ignoring it the farther into finals we got at Purdue and we began to do more than was put onto the checklist. It got as bad as using a wet wipe to clean the gripper wheels right before each match!
I win! XD
Pre-Match Strategy Sessions Chris Fultz General Forum 11 21-04-2007 16:07
Making pre-match deals Cyberguy34000 Rules/Strategy 39 09-01-2007 23:23
White Paper Discuss: 30 Tips for 2006-Checklist for post-ship/pre-competition KathieK Extra Discussion 1 27-02-2006 18:54
Checklist Francis-134 Rules/Strategy 1 16-02-2003 17:51
Pre-Match/Post- Match Pit Routine Mark_lyons General Forum 14 31-03-2002 15:19
