I have a problem trying to cause the piston going forwards and backwards.
What I`ve tried to do is to move the piston backwards when the user clicks on the joystick`s trig and to move the piston forwards when the user get rid of the joystick`s trig. I had a problem which seemed ambiguous for me and I couldn`t find the error, it compiled successfully. I made sure the spike is plugged in the proper relay, and the joystick is plugged in the proper port. Here is the code: if(p1_sw_trig) { relay1_fwd = 0; relay1_rev = 1; } else { relay1_fwd = 1; relay1_rev = 0; } but it doesn`t do anything . |
| programming pneumatics problem | program1 | Programming | 4 | 18-02-2008 17:35 |
| Pneumatics Rookie Problem | Squishylizard | Pneumatics | 4 | 06-02-2007 17:30 |
| pneumatics coding problem (or technical) | wildabyss | Programming | 2 | 22-02-2005 22:16 |
| pneumatics coding problem (or technical) | wildabyss | Pneumatics | 2 | 22-02-2005 22:16 |
| Pneumatics Problem + possible fix | Srkasner | Pneumatics | 4 | 24-02-2004 10:39 |
