Go to Post Mentor: How is that held in place? CAD Lead: Go to the hardware store and buy a bag of constraints and put the constraints on the robot. - Kenyow [more]
Unread 31-03-2008, 09:01
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
pic: Team 358's Backup battery
Unread 31-03-2008, 09:08
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: Team 358's Backup battery
Where did your negative wire go?
We need to figure out *why* this happened. 1885 has a backup battery charger circuit that keeps charging our batteries to 8.5-9.0 volts and we're worried the batteries will explode. We now have to keep replacing the batteries in between matches anyways (what we were trying to avoid) and also have to run them down. Changing the battery causes us to (even with the utmost care) pull out or dislodge a sensor or pwm wire, which has devastating results elsewhere on the bot.
I didn't design our circuit, but our electrical mentor says we are using the standard FRC backup battery charger circuit and have mounted it on a PCB in such a way that we can also power the IR board off of it (separate circuits, same PCB). I showed the circuit to an EE at work and gave him a description of our problem. He said that at first glance, using a different-spec'ed zener diode may help to not overcharge the battery.
Any thoughts on this?
GitHub
Unread 31-03-2008, 10:36
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Nice photo Mike!
We keep a history of parts that failed, so we can add your photo to the archives. I saw you working, and I want to apologize for not taking time to stop and say hi, but I always seemed to be between emergencies and I started having trouble keeping straight which pit I was supposed to be in next.
This backup battery came loose during the match and was damaged. It wasn't due to the charging circuit. Typical electrical vs. mechanical debate that the battery lost.
The black wire shorted at the battery terminal and the battery fell out of the robot and started to smoke on the field at the starting positions. The black wire got yanked to stop it I believe.
Unread 31-03-2008, 13:01
fatjoe3833's Avatar
fatjoe3833 fatjoe3833 is offline
Your GP is showing!
AKA: Joe
FRC #0545 (Robodawgs)
fatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud of
I was wondering why everyone was looking at that battery! I never got to see it up close.
Stony Brook University Class of 2011
Team 545 Alum
2007 SBPLI Regional Winners
SBPLI Regional Volunteer
Unread 31-03-2008, 14:15
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
My guess from looking at the failure mode, is that the damage severely bent the strap that tied to the next battery in the pack. When this occured it likely shorted out the first cell in the pack. Fully charged this cell could deliver several amps, enough to heat the strap and the battery and perhaps even welding the strap in place. The other cells in the pack are likely fine and could be used in other applications.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 31-03-2008, 20:35
Bcliff358's Avatar
Bcliff358 Bcliff358 is offline
Team Role: Leadership
Bcliff358 is just really niceBcliff358 is just really niceBcliff358 is just really niceBcliff358 is just really niceBcliff358 is just really nice
After that match I went down to talk to the drive team when they came and said that the robot was on fire. I wanted to know if Dave was anywhere near the robot (terminals up)
Long Island Finalists 4 years straight
Backup Battery Tottanka Electrical 31 06-01-2008 22:41
Backup battery failure comwiz7 Electrical 1 20-02-2007 07:40
backup battery carbuff Electrical 1 19-02-2007 08:28
pic: Backup battery ends match inside a different robot artdutra04 Extra Discussion 19 22-10-2006 14:46
backup battery nirty Electrical 1 08-02-2006 14:40
