Go to Post You should take in to consideration who you are putting on to the field, not what. - NorviewsVeteran [more]
Unread 01-04-2008, 11:36
kirtar kirtar is offline
Alumnus
FRC #0461 (Westside Boiler Invasion)
Rookie Year: 2007
kirtar will become famous soon enough
Swerve drive 4, 2+2?
Recently, I've been looking into omnidirectional drive systems (as defined in the whitepapers by Ian Mackenzie). It seems that my team is leaning toward prototyping a crab/swerve drive for next year.
There seems to be disagreement in terminology in this area, as some consider swerve as a subset of crab and vice versa. As clarification, I consider crab drive to steer all 4 wheels dependently, keeping them all at same angle (often by running one chain around the whole thing). I consider swerve to be a case where either all four wheels turn independently of each other or when two pairs of whells turn independently of the other pair.
As this has come around, I have a few questions:
1) On a 2+2 Configuration, is it usually arranged front/back, left/right, or does it really not matter?
2) Are there advantages in terms of performance of a crab as compared to a swerve and vice versa (except weight and complexity of building and programming)?
Swerve drive control system dpick1055 Programming 8 22-01-2007 19:06
A Swerve Drive Question lndnny Technical Discussion 10 20-07-2006 08:09
Swerve Drive Whitepapers/Info Ryan F. Kit & Additional Hardware 1 20-10-2005 00:51
Swerve Drive on a Jeep Karthik Math and Science 3 01-02-2005 17:50
Swerve Drive Jeff Waegelin Technical Discussion 14 17-09-2001 08:06
