Go to Post FIRST is an opportunity for me to tackle problems that have long been solved. - Madison [more]
Unread 06-04-2008, 22:07
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Where to Learn Electrical Online
The other day I was taking apart my VEX controller because I was bored and thought to myself, "there is so much in here that I don't know" when it comes to the basic stuff for FIRST I know most of it but, this knowledge doesn't help a lot if I plan to go into electrical engineering in the future. After searching google for about an hour today I haven't really found a place where I can learn more about electrical components and (relatively)complex circuits. I was hoping someone here would have a place where I can learn the basics of all plain electrical components (capacitors, transistors, resistors, integrated circuits, etc. etc.) and how to implement these components. Does anyone know of a website to help me?
Unread 06-04-2008, 22:12
Scott Carpman's Avatar
Scott Carpman Scott Carpman is offline
FRC #1155 (SciBorgs)
Scott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud of
Re: Where to Learn Electrical Online
MIT's opensource education service could help you out with this, perhpas in the EE department.
RPI '12
Unread 07-04-2008, 00:05
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
As a member of academia, I don't think I'm supposed to do this, but I've used Wikipedia on plenty of occasions to brush up on my electrical basics.
You will want to look at basic DC circuits first:
Components:
Resistors
Capacitors
Inductors
Concepts:
DC Voltage
Current
Resistance
Equations:
Ohm's Law
Kirchoff's Current Law (KCL)
Kirchoff's Voltage Law (KVL)
Then move on to the basic digital stuff:
Semiconductors
Diodes
Transistors
It will be a lot of reading - and you definitely can't learn it all at once - but this should get you started.
I'd recommend letting AC systems wait until college since (1) there are none in your Vex controller (unless you are using a power adapter) and (2) you need to have a strong grasp of complex numbers, phasors, and frequency-domain transforms to be able to do the fun stuff.
Unread 07-04-2008, 00:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It was a lot easier when you could actually see the parts, with all the modern surface mount components, now you need a microscope to see a resistor!
When we were about 10, my twin brother and I started with a very simple single transistor sound amplifier. By the time we were 12 we (and our older brother) built a Heathkit color TV, a year later a tube oscilloscope from scratch, and then he went on to make all kinds of neat stuff, but I got into cars instead.
Maybe one of those old 200 in 1 Electronics Experiment kits like they used to sell at Radio Shack would be a good place to start? They have big enough parts that you can see what's going on, along with good literature explaning how the circuits work. Look on ebay or thrift stores...
Unread 07-04-2008, 03:44
R2K2D2 R2K2D2 is offline
AKA: Raj
R2K2D2 has a spectacular aura aboutR2K2D2 has a spectacular aura about
Send a message via AIM to R2K2D2
Andy, have you taken Physics yet? Even in high school physics you go over some very basics and fundamentals of electronics and components. If you haven't I would suggest try to swing by a local university or community college bookstore or even your local library, if it's good, and see if they have physics textbooks you can buy/borrow. A very common physics text at the university level is Physics for Scientists and Engineers by Tipler. Another common book is Physics for Engineers by Halliday Resnick and Walker. You can also Amazon search these and purchase them for studying. The physics textbooks will give you some basic fundamentals and explain these, mathematically, in algebraic and introductory calculus concepts, so it should be easier to understand.
Once you go through those I would suggest looking at university/community college bookstores for an introductory electrical engineering circuits book. This will go into a lot of detail on not only the basic electrical components but also integrated circuits (ICs). It will start off probably explaining ICs with operational amplifiers. Be careful when looking at the college level texts because for some universities up through calculus 3 and differential equations can be a pre-requisite for some circuits classes. So, the mathematic descriptions can be very complex. But, I'd suggest getting a hold of some text books, start off at your local library.
Unread 07-04-2008, 04:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Those Radio Shack electronics any good? I never had one but they always looked pretty neat. A little pricey though.
Parallax has some good stuff for learning. It too is not free though, but you get to play with it.
Unread 07-04-2008, 06:42
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Andy,
I have found the following book, intended to teach the elements of electronics to non-EE scientists (such as chemists and physicists), to be extremely useful as an introductory text into electronics: Electronics and Instrumentation for Scientists by Malmstadt, Enke & Crouch
I know that this book is over 25 years old but, IMHO, it is still very relevant to the beginner. For example, the chapter on microcomputers will seem a bit dated until you realize that functionality of the 6' racks in 1981 is basically the same as the PIC microcontroller chip in your robot controller.
Good Luck,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 07-04-2008, 07:26
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Go here and get yourself the 2007 ARRL softcover closeout version for only $ 19.95
http://www.arrl.org/catalog/index.php3?category=Technical%2C+Electronics%2C+an d+Communications+Reference
You will notice there are several great mentors on CD with amateur radio 'callsigns'.
Ed Barker
Unread 07-04-2008, 07:56
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Don't laugh at me...but here is what I've done.
My daughter, 11 years old was interested in electronics. So I found radio shack had this kit called snap circuits:
Snap Circuits
It cost $90 for the grand kit, and she's already put together the AM radio circuit in less than 2 weeks. Granted....she's doesn't KNOW what everything is doing....that's where dad kicks in with a multi meter and explains when you measure across this resister in series you should expect to see this voltage drop....and teaching the basics of ohm's law.
However, I am a firm believer the best way to learn is you have to get your hands on it, reading stuff online or books is for the birds, getting your soldering pencil out is the way to learn but costly....the rat shack kit above is the good solution for hands on training, even for my 11 year old. By the time she's old enough to be in FIRST robotics, I hope to have half my brain in hers.
I really wish we all had download ports in our brains, we could reprogram are kids or even our wives, er uh...well download and share information with others.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 07-04-2008, 09:52
MrForbes's Avatar
AKA: Jim
Neat idea, but then we'd miss out on life! Seems some of us learn best by making mistakes.
Reading about electronic theory will only get you so far...you need to get some parts and play with them! That's why I recommended the old Radio Shack experimenter boards. They were way too expensive for us when we were kids, so we'd get broken and surplus stuff and play with it (I have a nice molten solder scar on my finger from when I was 10).
Unread 07-04-2008, 09:57
Controls Engineer
AKA: chakorules
I think the snap kits from radio shack above are pretty close to the expermitter boards, without the soldering :-)
Favorite CD quote:
Unread 07-04-2008, 10:02
MrForbes's Avatar
AKA: Jim
We may be talking about the same thing, the boards I'm talking about use little springs to make connections, no soldering needed.
Unread 07-04-2008, 18:57
Andy L's Avatar
FRC #1458
I'm in physics right now and we're just starting static electricity now and are going into electricity right now.
Snap Circuits
I have one of these kits somewhere around my house
Thank you for your help so far everyone
Unread 07-04-2008, 19:11
Nate Edwards Nate Edwards is offline
SWARM Head Mentor
FRC #0957 (SWARM)
Nate Edwards will become famous soon enough
I was in FIRST in high school and now serve as a mentor, one of things that sparked my interest in Electrical Engineering was taking apart different things. As a student I do recommend wikipedia and yes there are several kits out there that can teach you the electrical side. If you want to combine that with a robot there are examples such as:
TekBots (eecs.oregonstate.edu)
BoEBot (Parallax.com)
and I would also recommand looking for introduction to electrical engineering classes at colleges around the country, having toured places like MIT and CMU they have many online resources where you can look at whats taught to first term students at those places. Of course I recommand TekBots because its at my school, but many colleges have simple kits that come with a breadboard or a pcb (printed circuit board) which introduce to those components mentioned by the others. Specifically in the vex brain there are two microcontrollers from microchip which is a leader in the microcontroller market, I would also look up this on wiki.
Hope you get inspired by Electrical Engineering like I did
South West Albany Robot Mechanics
2002 Pacific NW Regional Rookie All Star Award Winners
2003 Pacific NW Regional Daimler Chrysler Team Spirit Award Winners
2004 Pacific NW Regional Johnson & Johnson Sportsmanship Award Winners
2004 Pacific NW Regional Winning Alliance (492 (#1 Seed), 1031, 957)
2003 & 2005 Pacific NW Regional Chairman's Award Winners
2009 Oregon Regional Woodie Flowers Award Winner
  #15   Spotlight this post!
Unread 07-04-2008, 19:24
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Rookie Year: 2007
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Also if you don't want to purchase check out your local library for books, some good ones I have found are "Electronics For Dummies" and if you want projects go for "Electronic Projects For Dummies". Both of these books are farelly good about teaching some of the basic components.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
where to find pool noodles -- online or in VT circuscommando Kit & Additional Hardware 5 28-01-2008 20:33
Where to View 2007 Kickoff Video Online? brianafischer General Forum 13 07-01-2007 13:28
Where do I learn how to make those LEGO Trophies? Amanda M FIRST Lego League 10 17-12-2004 03:26
Where can I learn some mechanical before build season John JediMaster General Forum 7 23-09-2003 20:27
Need to learn PBASIC...Where Should I Go? IMDWalrus Programming 5 29-04-2003 16:43
