Go to Post Read the manual. Know the manual. Love the manual. - Koko Ed [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations > The Blue Alliance
Unread 10-04-2008, 14:15
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
[TBA]: Total Points Put up by team and year
I wrote a simple function using the API to get the averaged or unaveraged points scored by teams and year.
(Excessive unnecessary comments...)
PHP Code:
function getScore($teamnumber$year$average FALSE)
$competitions = array(); //Contains TBA assigned "eventid"'s for events attended by team X
$score 0//Initialization of $score. Not sure it's entirely neccisary
$events make_array(get_events(NULL$yearNULL)); //Assigns array of events that occured in designated $year to $events
foreach ($events as $event){ //breakdown of each $event within $events
if($event["week"] < 90){ //If event is NOT champs OR off-season
$attendance make_array(get_attendance($event["eventid"], $teamnumber)); //Lookup of $teamnumber within the $event
if(count($attendance) > 0//If the array has data
$competitions[] = $event["eventid"]; //Add eventid to array of competitions attended
        else{
//Otherwise
           //Do nothing
    foreach(
$competitions as $compID){ //Breakdown of each $compID (eventid) withing $competitions
$matches make_array(get_matches($teamnumber$compID)); //lookup matched for each team at the event
$record make_array(get_official_record($teamnumber$year)); //official record of team by $year
foreach ($matches as $match){ //breakdown of $match in $matches
$matchid $match["matchid"]; //assigns matchid to a variable
if($match["red1"] == $teamnumber || $match["red2"] == $teamnumber || $match["red3"] == $teamnumber){ //determines if the team is on the red alliance
$alliance "red"//Assigns alliance variable an alliance name
        else{
//if they weren't red
$alliance "blue"//must be blue
        if(
$alliance == "red"){ //If alliance is RED
$score += $match["redscore"]; //add redscore for specific match to the total score
        else{
//If alliance is blue
$score += $match["bluescore"]; //add bluescore for specific match to the total score
    if(
$average){ //if parameter $average is set to TRUE
$average_score round($score/count($matches), 0); //round the amount of the total score over total matches in question
    else{
//If parameter $average is set to FALSE [DEFAULT]
$average_score $score//$average_score is the total score
    return
$average_score//output $average_score
When i call it as getScore(330, 2007); or getScore(330, 2007, TRUE); (or even 2006 instead of 2007) and It outputs a score. The score doesn't match up with my manual calculation (2007 unaveraged should be 3,000+ and only returns around 870). If I change the year to 2008 however, it returns 0 (or if I remove the $score initialization line, outputs nothing). Someone suggested that maybe its trying to grab data from 2008 champs and therefore throwing off the data. However, I figured since no matches were listed for champs it most likely wasn't the issue. Nonetheless I added the check for which "week" the events were in, if (week < 90){
Any ideas how to resolve this issue?
[TBA]: Schedules and TBA API proegssilb The Blue Alliance 3 09-03-2008 15:55
[TBA] TBA Presents... Soldering and Multimeter Tutorials Greg Marra General Forum 0 27-01-2007 20:15
pic: YMTC: 150 points or 100 points? CD47-Bot Extra Discussion 4 25-03-2004 01:53
put and get Robert Hafner Programming 4 10-02-2004 10:58
Awards and points... Ian W. Rules/Strategy 4 24-03-2002 13:30
