Go to Post Baker, Skierkeiwicz, one more word out of you two and I'll have to pull out the Clipboard of Doom :p - Jessica Boucher [more]
  #16   Spotlight this post!
Unread 12-04-2008, 00:33
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
Re: pic: FRC 1771 Swerve Module
Originally Posted by Ice Berg View Post
In the picture above, of the module with a blue wheel, I was wondering how those sprockets drive the shafts. It doesn't look too me like they're hex, or keyed.
Right behind that snapring you see is a 1/2" hex followed by a step of 1/2" round for a bearings then it steps down to 3/8" hex for the wheel then at the very end it turns into 3/8" round for another bearing and snapring.
A guy who likes robots.
1625->3928->148->1296->971 oh dear
  #17   Spotlight this post!
Unread 13-04-2008, 00:09
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Rookie Year: 2007
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Well, my team doesn't have the machining capabilities to make a shaft like that, however, I thought about it and I think I've found a simpler solution in terms of machining. Instead of lathing anything on the hex shaft, we would use a 3/8" shaft all the way through, and where we needed bearings (on either side of the module) we would make a sort of bushing whose inside would be broached to a 3/8" hex, and whose outside would be a 5/8" dia. circle. This way we could put a hex shaft through the center and use a 5/8" bearing around the outside, and snap-rings to hold it all in place.
  #18   Spotlight this post!
Unread 13-04-2008, 00:36
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
That method would definitely work although bigger bearings are more expensive and its heavier but if thats how you have to do it then by all means use that method. It will definitely work and would be less labor intensive.
Mentor 2415
pic: 1625's swerve module (better pic) Aren_Hill Extra Discussion 25 22-07-2008 19:14
pic: FRC 1771 Swerve sdcantrell56 Extra Discussion 5 10-04-2008 16:17
pic: Team 148 Robowranglers: Swerve Module and Motors Brandon Martus Robot Showcase 27 24-02-2008 22:29
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
