Go to Post Seating is limited. Be sure to apply deodorant and brush your teeth. - Wayne TenBrink [more]
Unread 11-04-2008, 15:12
Ashinkizer Ashinkizer is offline
Ashinkizer is an unknown quantity at this point
Help with CMUcam2 serial communication
Hello all,
I'm using a cmucam2 and need some help, this was the best site I could find.
I'm interfacing the camera to an oopic S microcontroller. The controller and camera power sources have a common ground. The camera has a 5V and 0V reference taken directly from the controller.
The thing is:
If the camera is ON, sending any command results in a NCK 95% of the time.
If the camera is OFF, commands work as they should all the time! I guess that its drawing power from the serial pins.
I don't know what's going on, this has me completely baffled.. I guess its something to do with voltage levels but its beyond me. Any help would be appreciated.
Thanks,
RS232 (Serial) Communication To OI bglass Programming 9 07-07-2007 04:04
Need Help With Maplab C programming on serial communication loveheb3 Programming 0 04-06-2007 21:24
Labview and communication with peripheral device help jaijaidin LabView and Data Acquisition 3 26-01-2007 19:17
Serial Communication Problems with LabVIEW FRC Toolkit Jon236 LabView and Data Acquisition 1 28-12-2006 11:57
Serial Communication in C++ Adam Shapiro Programming 8 21-01-2003 12:49
