Go to Post Focus on solving the problem, not on being deliberately creative. If you effectively solve the problem, creativity is naturally leveraged as part of finding a great solution. - Jim Zondag [more]
Unread 12-04-2008, 19:16
Ashburn Ashburn is offline
FRC #0600
Ashburn is just really niceAshburn is just really niceAshburn is just really niceAshburn is just really niceAshburn is just really nice
String Theory: <G22> at the Championships
This is a suggestion for those attending championships who are concerned with violating rule <G22>, also known as “breaking the plane.” Though I cannot be sure that this suggestion will work in practice, it is very easily implemented and I thought I ought to submit my string theory for those who might want to try it.
The idea:
Attach a length of brightly colored string (EDIT: or nylon rope) to the bottom of your robot, near the back end (if your robot has a rear). The string should be coiled and laid under the robot within the appropriate dimensions prior to each match. The length of the string will vary from team to team because the robot, with the string fully extended, will need to adhere to the 80” rule. I imagine that a 1-to-2-foot length of string will probably be sufficient to achieve the goal.
The result:
At the beginning of the match, as soon as the robot moves forward from the starting position, the coiled string will uncoil and trail behind the robot. The length of the string and where it is attached to the bottom of the robot will determine how far behind the robot the end of the string lags behind while the robot travels forward. When the robot stops moving forward, so will the string. Most importantly, however, when the robot backs up, the tail end of the string will remain in place. The string thusly provides a buffer zone for backing up and turning when the robot is in the vicinity of a lane marker or finish line and, ideally, prevents many of the <G22> violations that are most likely to occur during the heat of competition.
The positives:
+ Once completely over a line, the string itself will not break the plane of a lane marker or finish line because it is not rigid, but slack.
+ The main structure of the robot will have a buffer zone in which to maneuver even after crossing a line, because the string (which counts as part of the robot) will not yet have fully crossed over the line.
The negatives:
- A robot will have to travel farther in order for the trailing string to completely cross a line and for the robot to receive points for doing so.
Attached is a series of slides roughly illustrating the concept. If you have any comments, suggestions, or additions to the positives or negatives, feel free. I simply wanted to put this out there. Good luck to all teams!
Last edited by Ashburn : 12-04-2008 at 19:32. Reason: Strings may engender entanglement, nylon rope might be better...
Unread 12-04-2008, 19:18
Vikesrock's Avatar
Happy Birthday! Vikesrock Vikesrock is offline
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: String Theory: <G22> at the Championships
Seems to me like it could be a huge entanglement hazard with both mechanisms and wheels of other robots
Unread 12-04-2008, 19:23
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
Quite true....but I think he may be on to something.
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 12-04-2008, 19:28
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Well, considering our robot extends to 79.5" in the worst case... i dont think we will be doing this )=
its a good idea though, but i don't like the entanglement issues.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 12-04-2008, 19:43
Corey Oostveen's Avatar
Corey Oostveen Corey Oostveen is offline
FRC #2771 (Code Red Robotics)
Team Role: Coach
Corey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant futureCorey Oostveen has a brilliant future
I like the concept of this! Very good idea. Like others have mentioned entanglement could be an issue.
Great idea keep on thinking!
Unread 12-04-2008, 19:49
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
This reminds me of the extending tape measures of zone zeal a few years back. Overall I like it. It will be tough to make sure people don't step on your tale, but I really think you are on to something. Very clever...
Unread 12-04-2008, 19:59
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
I like the idea, although you'd have to make sure you don't get 'hooked' on to the center divider while going around the end lines.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 12-04-2008, 20:11
wingnut1705's Avatar
wingnut1705 wingnut1705 is offline
AKA: Kevin
FRC #0453 (Gears)
wingnut1705 is an unknown quantity at this point
Send a message via AIM to wingnut1705
I had thought about this during the Detroit Regional, but our team didn't have the extra space so I didn't bring it up. Entanglement would be a problem, but out of the box ideas can be a great way to solve a problem. This idea should be tried at Atlanta.
2008 Detroit Regional Finalist
Unread 12-04-2008, 20:36
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Somehow this seems inconsistent with my pet peeve of seeing students walk around with their shoelaces untied. I tend to freak out, imagining that they're going to trip, most likely while carrying the robot.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 12-04-2008, 19:47
Alex Golec Alex Golec is offline
FRC Advocate
no team (FiM Volunteer)
Alex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond repute
Hmm... this seems similar to the zip-ties used in 2005 in order for the robot to be in contact with the loading zone plate, because clearly straddling the plate was not enough. Three years, and we're still improvising to make up for a lack of common sense in the rules. However, this is tangent to the topic.
The string could be an entanglement hazard with other robot's wheels and be a nuisance overall. Great creativity though!
-Alex
Unread 12-04-2008, 20:03
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
-Alex
Exactly what I was thinking!
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 12-04-2008, 21:50
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
I respectfully disagree. You might not like <G22>, but it is crystal clear and easily enforced. Tying string on your robot is lawyering the game, in my opinion, and the time spent coming up with schemes like this might be more fruitfully spent learning to drive your robots in a way that did not violate <G22>.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 13-04-2008, 00:46
Valley Raider Valley Raider is offline
FRC #0955
Valley Raider is just really niceValley Raider is just really niceValley Raider is just really niceValley Raider is just really niceValley Raider is just really nice
With all due respect lawyering the game is exactly what FIRST does, there just not very good at it. Every year they come up with some silly rule that dies need to be their. <G22> is a rule that has decided regionals, and not because of human driving. I have seen matches lost because two robots driving in Hybrid period have run into each-other and cross a line drawing a penalty. I know some will clam that this can be prevented but the fact is this rule is nit-picky.
FIRST makes up roles for their games without thinking about the practicality of them during game play. A great example of this is the 6 foot role that originally existed in the opponents home stretch. They pulled this rule after it became clear that the most teams were not going to be able to get the second trackball down. I say most because my team had a plan with in the rules for getting it down that would have work. This rule didn't need to be removed but it was because it offered nothing to the game.
<G22> is a rule that doesn't nothing to help the game. You already can't play defense for longer then 6 seconds. Tell me what does a team gain from driving backwards, nothing so why does this role need to be in place? Lawyering around the roles is part of the game and if someone can come up with a good way of getting around a pointless rule then good for the its time well spent.
Plus when your Robots in a crate there not much you can do to learn how to drive it better.
Unread 13-04-2008, 00:58
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
Team Role: Coach
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
i think the whole point of the role is to keep robots moving in a similar direction and to promote scoring to make it more exciting but in practice it makes the games less fun to watch because they are often decided by penalties.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
  #15   Spotlight this post!
Unread 13-04-2008, 01:01
Onward through the fog.
It's a little strange to see the word, rule, changed into the word, role, in this discussion - at times skewing everything a bit more.
~ Helen Keller
(1880-1968)
G22 Direction of Traffic Hilarity Kevin Sevcik Rules/Strategy 16 17-01-2008 22:30
String Theory Michael Hill Math and Science 20 02-09-2005 14:11
problems with G22 JMH Electrical 2 19-01-2005 20:52
100yr anniversary of Einstein's Theory of Relativity. Einstein stage the place to be? Elgin Clock Rumor Mill 6 08-09-2004 09:38
