Go to Post No one shall stand between me and my sleep. - Adam Y. [more]
Unread 14-04-2008, 19:13
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Encoders, gyro, and accelerameters
Does anyone know exactly where to buy and does anyone know exactly how to set each one up.
Thanks a lot.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 14-04-2008, 19:59
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Encoders, gyro, and accelerameters
The sensor strip that came in the Kit of Parts is documented here. You can't buy more of those, but you might be able to convince a friendly team to let you use any that they didn't.
There are other sources for similar components, but I don't have details since we didn't buy or use them.
We use the US Digital quadrature encoders included with the AndyMark SuperShifter gearbox. They work perfectly with Kevin Watson's encoder support library for FRC. I'm the one who specified those parts for our team's use a year ago, so I do know where to get them and how to connect them. All that information is here: http://www.usdigital.com/products/e4p/
Unread 14-04-2008, 23:23
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Encoders:
www.usdigital.com
www.grayhill.com
Gyros and accelerometers:
www.analog.com
The Grayhill and Analog Devices products are available from DigiKey.com (among others).
I have used the Grayhill 61K, 61R, 63K, and 64R encoders in the past.
I have also used the Analog Devices ADXRS150 150 deg/sec gyro evaluation board (PDF: http://www.analog.com/UploadedFiles/...XRS150EB_0.pdf)
The Analog Devices ADXL204 Evaluation Board is the same chip used in the kit accelerometer (PDF: http://www.analog.com/UploadedFiles/...DXL204EB_0.pdf)
Good luck!
Unread 15-04-2008, 18:19
HighLife's Avatar
HighLife HighLife is offline
Mentor
FRC #0245 (Adambots)
HighLife will become famous soon enough
Send a message via AIM to HighLife
We went with a gyro from Sparkfun (We used the ADXRS300) these are nice because all you have to do is solder on the pwm cable and put it in a project box and your ready to go. They also sell accelerometers like that. Just use Kevin's gyro code and you should be good to go.
AdamBots.com- Winner of 7 Best Website Awards!
RobotC and Quad Encoders KevinReid Programming 6 03-04-2008 22:00
Wiring Gyros and Encoders? SuspectZero Electrical 3 03-02-2008 15:30
Encoders and putdata theycallhimtom Programming 3 09-02-2006 19:24
EEPROM and Encoders Bharat Nain Electrical 7 01-12-2005 10:06
Testing and Cause of Failure for Encoders and Hall Effect sensors ChrisH Electrical 28 19-09-2005 01:07
