Go to Post Step 1. Understand the game and how to win the match and the event. - Chris Fultz [more]
Unread 15-04-2008, 12:50
berkanbaba berkanbaba is offline
berkanbaba is infamous around these partsberkanbaba is infamous around these partsberkanbaba is infamous around these parts
Exclamation C Programming Homework Help Needed
i have a question about c programming.can you help for the solution.thank you . i just use C not C++
Question:
Write a C program for a binary notation simulator for positive integer numbers. Your program will ask and get positive integer numbers from user. Program will stop asking new numbers if 0 is input. It will display the binary representation of the input number and the minimum number of digits required to represent that number as given in the sample run.
Sample Run: (Italic and bold letters indicate the user input)
Enter a positive integer: -5
Enter a positive integer: -3
Enter a positive integer: 5
It is 101. At least 3 digits required.
Enter a positive integer: -2
Enter a positive integer: 7
It is 111. At least 3 digits required.
Enter a positive integer: 0
Stop... Bye..
C Programming Homework Help Needed Pat McCarthy Programming 53 27-09-2008 22:15
programming help needed krunal Programming 3 29-01-2007 00:18
HELP-URGENT PROGRAMMING HELP NEEDED Rohith Surampudi Lego Mindstorm Discussion 1 24-03-2006 23:05
URgent Programming Help needed rcubes85 Programming 4 15-02-2005 23:21
