Go to Post Good thing that this is FIRST and not FIRD (For inspiration & Recognition of Dancing) ... :) - Jason Morrella [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 16-04-2008, 13:34
Martino's Avatar
Martino Martino is offline
FRC #1825
Martino is on a distinguished road
Send a message via AIM to Martino Send a message via MSN to Martino
Question Help with a job I am doing-how to emboss on an oval part?
I am working on a job and need to emboss a logo on the side of an oval part and can't figure out how to do it... so i thought I would post on here and see if anyone on here knows how to do it. I attached 2 pics of what I am working on... the 2nd one is the logo that I am trying to put on the first one(I have the sketch for the logo)... I want to put the logo on the bottom side in the pic.
any help would be great!!!!
thanks,
Martin O
ID:	6590  Click image for larger version
Unread 16-04-2008, 13:42
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
Re: Help with a job I am doing-how to emboss on an oval part?
Ok, emboss can get a bit tricky if you are not used to it. First thing, is to make the part you want to emboss on (you have already done this.) Then, make a work-plane(if you look through your work-plane it will be looking at where the emboss is going.) This work plane should not intersect your part. Now, make a sketch on the plane. And put your logo on the sketch. Make sure that it does not go over the edge of your part.(this will cause major errors) Finally, tell it to emboss, make sure your direction is good, and you should be done. Please post if there is anything that I said that doesn't make full sense.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 16-04-2008, 13:50
Martino's Avatar
FRC #1825
thanks for the reply! i have to get to work but will try this when i get home... will this curve the embossed sketch to match the curve of the part or not? that is what i am really trying to do here... sry i didn't say that in my first post
Unread 16-04-2008, 13:54
Molten's Avatar
AKA: Jason
You cannot curve a sketch. They are always flat. However, when you emboss with the sketch, it will create the emboss that follows the curve.
Unread 16-04-2008, 13:59
Martino's Avatar
FRC #1825
ok thank you very much!!! if i have any more Q's i will post them
thanks again!,
Martin o
Unread 16-04-2008, 23:40
Martino's Avatar
FRC #1825
Thumbs up Re: Help with a job I am doing-how to emboss on an oval part?
thank you for all you help!!! it worked just like i wanted it to! so thank you
Unread 17-04-2008, 13:10
Molten's Avatar
AKA: Jason
No problems. Emboss is a hard tool to learn on your own. Let me know if you come acrossed any problems in the future.
Unread 17-04-2008, 13:21
Martino's Avatar
FRC #1825
ok well do!
help with the inventor[robot part missing] (ajuda no inventor[parte do robo faltando] team 2244 Inventor 6 12-02-2007 06:16
pic: doing a 35 minute wire job redbarron Extra Discussion 4 10-02-2007 23:21
17yr old looking for a part time job Buster Career 0 17-12-2003 13:55
How is everybody doing?? Heather 45 General Forum 1 10-02-2002 20:47
How iseveryone doing Matchew General Forum 4 26-01-2002 23:30
