Go to Post Great teams derive from great mentors. - Barry Bonzack [more]
Unread 26-09-2008, 18:21
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Rookie Year: 2007
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Re: Programming with the 2009 controller
Closest thing you'll get is the Guide that one of the team members of Team 1817 has done about programming a National Instruments Compact Rio (NOT THE FRC VERSION).
http://www.team1817.org/cRio_report.html
If the code there intimidates you, be assured that programming the 2009 NI CRio FRC will be much more easier. From what I understand right now, there will be many demo VIs (programs in LabView) that will explain how to program in LV and program a robot in LV, and hopfully, teams will recieve/download a default code(or VI) for LabView which with it teams can control a robot like you would with the Default Code for MPLab in previous years, just that you will have much more options of changing values easly in order to:
- Chose the method of driving the motors (1 joystick, 2 joysticks, omni....)
- Defining input/output for analog and digital components
- and probablly much more!
and all that without having to create too much of your own code.
So I think the best thing for teams (same goes for teams that are looking forward to use only C/C++) to do now is to understand how to use LV to program a robot (know how to use shortcuts, values, loops, statments etc...) so once you receive the robot controller and Labview (hopfully) with the Default Code, you'll be able to change the code to fit your robot easly.
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 27-09-2008, 00:19
pollyproof12 pollyproof12 is offline
AKA: Jarrett
FRC #1865
pollyproof12 is an unknown quantity at this point
so let me geth this right. keep in mind that this is my first year in the usfirst competition. they will give us default vi to modify?
Programmer
Unread 27-09-2008, 09:08
Yes. There will be examples and default code in both C/C++ and LabVIEW.
Greg McKaskle
Unread 30-09-2008, 10:07
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
Originally Posted by pollyproof12 View Post
so let me get this right. They will give us default vi to modify?
The LabvVIEW installation disks that come with the competition kit will already know how to build a FRC-cRIO project. So instead of saying "New Vi" you will say "New FRC cRIO project"
That project will build and deploy to the robot and work just like the "Default programs" of past years.
This base project can then be modified to your hearts content to build custom robot capabilities. There is also a large set of "custom" vi's created to support typical FRC components. The best thing is that you can drill down into these and see how they were built, and learn LabVIEW skills the same we learn most programming.
Note: the cRIO will probably be loaded with this program out of the box, so once wired up it should run without any software changes (just like past years)
Go to this forum to ask question of the teams currently beta testing the new hardware/software.
http://forums.usfirst.org/forumdisplay.php?f=743
There is not much there yet because people aren't asking questions (like yours).
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Purchasing the 2009 controller Tottanka FRC Control System 60 04-05-2008 19:44
How the heck do you use an XBOX360 controller with the chicklet?? waialua359 Control System 58 17-02-2008 12:43
Problem with the program downloaded to the controller itsme Programming 9 14-01-2007 12:12
Problem with the 2005 controller Guy_E Programming 10 18-12-2006 01:38
Programming The CMUcam for the Vex controller 987HighRoller Programming 3 24-06-2006 15:27
