Thread Tools |
Rating:
Display Modes |
pic: The new driver station
Re: pic: The new driver station
Edit: Oops, for some reason I thought they were using the B-type USB plugs when I saw this photo. There are indeed four regular (A-type) USB plugs. ![]() Last edited by artdutra04 : 21-04-2008 at 02:02. |
It looks like there are two stacked on top of eachother to me.
EDIT: Here, it is very visible in this pic: http://first.wpi.edu/driver_station_usb.jpg ~DtD Blue Valley Robotics Last edited by DtD : 21-04-2008 at 02:02. Reason: Image |
I'd guess a Dashboard computer occupies the other Ethernet jack?
According to the FIRST rep during the mentor Q&A, you're allowed to use a laptop to hook into the driver's station during the match. Any joystick that the DS can't read, the laptop probably can read. I don't remember if he said it is in the current plan that the drivers are allowed to use the laptop directly though. The possibilities for driver control are almost endless...
Now put a nerf gun on the thing and we'll get full keyboard and mouse support. That'll be fun
I'm a fan of creating a custom GUI in Java that not only displays whatever feedback but also provides advanced situation-based options for robot control. Then the Java would output commands via ethernet to the controller. Using Java3D you could even integrate whatever animations you've made in 3dsMax or Autodesk into the GUI. Or you could use Matlab toolboxes that dynamically calculate GA's or other such "AI" based upon sensor feedback and output new PID coefficients for whatever functions. After a couple of iterations, who knows, an AI may even be able to "learn" the different styles of each driver. Bah, I'm just rambling. It's nice to have a vision though. Last edited by JesseK : 21-04-2008 at 22:32. |
#10
Wow... if the dashboard capabilities had enough throughput, mount a tri-axial turret on the top, with a camera on the end of it. basically turn the laptop into an FPS, mouse moves the turret in 2 axes, q and e in the 3rd axis, wasd to move the holonomic drivebase, and you feed the camera out onto the laptop screen... crosshairs in the middle of the screen, adjusted so that clicking the mouse fires a (ball, tshirt, whatever) perfectly for the crosshaired target... Cool.
EDIT: On second thought, your turret only needs 2 axes... though q and e could be used to rotate the drivebase. |
#11
Gotta love Gameport to USB adapters.
It will take more than a new control system to make me give up my old 2 button CH Flightsticks. |
#12
Yeew, those header pins are nasty - can you say protective cover needed...
The USBs will also need some retention means to keep them in place when a robot hits the wall. All the talk of writing your own Java is great - except for the novice and other teams with little programming support. All in all, the FIRST hardware and software gets better each year, so no worries here. |
#14
From what they said at the mentor info session, a dashboard computer can be connected via one of the USB ports, and there was a certain packet size that could be sent bidirectionally between the control station and the laptop.
#15
The lower of the two Ethernet ports is for connecting to a laptop dashboard. It can also be used to "daisychain" several Driver Stations together so they can use the same WAP. The USB ports are only inputs for joysticks/ wheels/ gamepads etc. I don't have any info about the amount of info available through the dashboard port however... |
| pic: Why FIRST needs to make the driver station taller | Jay Trzaskos | Extra Discussion | 12 | 12-03-2007 08:57 |
| Have Any New Driver Advice? | thefro526 | General Forum | 38 | 27-02-2007 13:49 |
| Serial Driver and 2K6 Encoder Driver Not compatible | Tom Bottiglieri | Programming | 6 | 12-02-2006 01:11 |
| size of driver playing station | 663.keith | Technical Discussion | 1 | 11-01-2005 13:23 |
| New Serial Port Driver | Kevin Watson | Programming | 16 | 09-01-2005 01:56 |
