Go to Post Engineering is a balance between best performance, best cost, and best use of time. - GeorgeTheEng [more]
Unread 24-04-2008, 02:56
pludodog pludodog is offline
College Student
AKA: Joe Hall
None #0395 (2trainrobotics)
pludodog is a splendid one to beholdpludodog is a splendid one to beholdpludodog is a splendid one to beholdpludodog is a splendid one to beholdpludodog is a splendid one to beholdpludodog is a splendid one to beholdpludodog is a splendid one to behold
Send a message via AIM to pludodog
Unhappy Victor turning on and off under load, with non-IFI microcontroller
I'm trying to control a Victor (two 884's and an 883, all have the same problem) using the Arduino microcontroller. It outputs PWM signals that work fine for servos, and should work fine for the speed controller. When I vary the output with the motor disconnected the victor goes from red to orange to green as expected. When I connect the motor and give the speed controller a speed the speed controller flashes orange rapidly, and the motor makes a clicking noise, as if it were turning on and off quickly, but doesn't move.
Without the victor the motor works fine, the battery works fine, and the controller works fine. I haven't hooked it up to an IFI controller yet -- our only C controllers are in Atlanta and I don't want to remember PBASIC. I might build a timer circuit in the morning just to see, but it seems like the Victor is getting PWM signal fine.
Any idea what could be causing this?
jphiii
395 - 2trainrobotics
2005/06 NYC Champions
2005/06 Pittsburgh Champions
30 - Fury
RPM under load Demothesis Motors 1 12-01-2008 22:30
Issues with non working victor constant orange led dani190 Control System 10 21-12-2007 22:32
**FIRST EMAIL**/Championship Updates - Load In and Load Out and Finale Ticket Inform AmyPrib FIRST E-Mail Blast Archive 3 21-04-2006 11:08
Turning motors on and off in the KitGearbox? Andrew Blair Kit & Additional Hardware 4 31-12-2005 10:33
Victor turning off zeep25 Electrical 10 23-02-2004 18:35
