Ribbon cables
so i have been trying to add pwm cables to my robots, but i just cant seem to get it right. i made the connectors, pin groups, pwm library wire, but it isnt quite working. im not sure why there is a massive red slash in the middle and why it is not making all three wires, only two.
Re: Ribbon cables
Increase the width and see what happens. My guess is that Inventor doesn't think it can fit three leads onto the ribbon.
Re: Ribbon cables
Actually, as far as I'm aware, thats the way it works. It only does the two end cables and a swath of a color in between. Frankly, people dont usually need a photorealistic render, so the two round cables on the end and the filler in between do just fine for a program like inventor. In my robot, I did make one instance of a ribbon cable that was 4 cables of different colors... but I really just made two ribbon cables and put them next to each other... so you can't tell.
So you aren't doing it wrong, that is simply how inventor does it. |
| Ribbon cable | Pneumaticsman | Electrical | 4 | 08-02-2008 20:00 |
| Ribbon Cable | emusteve | Electrical | 6 | 13-01-2006 16:33 |
| Ribbon cable sources. | Rickertsen2 | Electrical | 9 | 19-01-2004 16:23 |
| Ribbon Cables for Digital Input | Caleb Fulton | Electrical | 5 | 06-02-2003 08:39 |
