Future use of cRIO?
I believe that the cRIO is set to be reused every year for at least som set of years, so would that have any implications on the placement and build of the the robot, since it has its own requirements and we have to move it from robot to robot on testing and demos?
Re: Future use of cRIO?
I heard this too, but I think it is only a rumor.
Just as the deployment of the cRio to teams has not yet been finalized - I believe that the decision on whether or not to give one as mandatory in the kit has not yet been made. I personally hope that they decide to make it mandatory since that might lower the cost for everyone.... and I think 90% of teams will want a new one each year. but then again that means that teams that don't want it or even worse - can't afford it have to get one despite their objections. but the counter-counter argument is that if it is mandatory then they can mass produce with certain numbers (+- the growth of FIRST) and thus lower the cost. If it is a team choice then the numbers may vary wildly from year to year and they will have to produce in small numbers which is more costly. Has getting a controller in the kit ever been a team's choice in the past? -Leav |
I went to the mentor's meeting (as I am a future mentor) of the new cRIO and control system in Atlanta on Thursday night. They mentioned that the cRIO will be more expensive than our current control system, but many of the parts in the cRIO are being donated by the vendors. They said at this point, teams should look at reusing their controller year after year, but they will have the cRIO available for purchase, you know... if for some reason your cRIO breaks or your team likes to keep your robots together year after year.
So basically... I believe they intend to "give" teams only one cRIO, and they can purchase additional ones as they like. So I believe you will reuse them year after year. |
RyanN is correct, their current plan is to give one controller to teams to be reused every year, while teams can buy an additional controller every year at an immensely reduced cost.
With teams only getting 1 cRIO; in the years after 2009 will the price of the KOP be different for rookies and veterans?
My question is how it will affect demos and build of robots. |
It would mean that we'd have to keep programs around so that if there was a call for the 2009 robot in 2010, we'd pull the unit from 2010 and put in on 2009 with the 2009 code, then switch back.
I'm not so sure that's a wise move. Maybe all teams get two, then it's get your own would be better. Sometimes demos come up suddenly while the robot isn't there. Two would make sure that practice robots could be built, or old robots kept alive for another year for demo uses. |
My only question is... will all the other components be reused, or will they be provided new? If the cRIO isn't going to be given each year, what about the power distribution board or the I/O boards? If they are given out each year, then this will make a reusable system much easier to build, and a simple plug and unplug setup will work fine and will be reliable. |
#10
I don't know about you guys but when 2010 comes around the corner I can tell you now that the 2009 controller isn't coming off of our robot!
![]() It might be a bit expensive but come on.... unless the cRio costs significantly more than the current controller I think it is highly reasonable to purchase a new one each year. a functional demo robot is almost worth it's weight in Dollar coins (in getting new students, mentors, parents and sponsors)! That is much more than the price of a controller no matter how they price it.... -Leav |
#11
Depending on how far you go with the cRio you could always install the IFI controller on the demo robot.
#12
The NI cRio retails for $3900 without modules |
#13
I was thus assuming:
These assumptions may not be true but if they all are (and that is not so far fetched in my opinion... then the price of the cRio will not be much much more than that of the IFI RC. even a $2000 price tag would not deter me from trying to get a new one each year. at least for the first 3-5 years. (by then the controller probably will be changed or updated anyway). -Leav |
#14
Integrated 400 MHz Real-Time Controller and 2M Gate FPGA for $2999.00 32 Channel Digital I/O module for $349.00 32 Channel Analog Input module for $799.00 8-Channel Relay, 60 VDC/30 Vrms, 750 mA (Relay Outputs) $299.00 As for the Pulse Generation... I guess we use the Digital I/O... I'm also being generous on the ports, there are much less in the actual system. Add this up and you get $4446.00 total, and all of these are modules, so if any single part breaks, you can replace it... and also, the FIRST Modules should be much cheaper, or will be made cheaper to FIRST teams. <-Talk about a run-on sentence... Last edited by RyanN : 29-04-2008 at 07:39. |
#15
| Students build SEGWAY in 3 months using Labview and the cRIO | neutrino15 | Programming | 31 | 27-04-2008 22:08 |
| Which operating system do you use/want to use? | neutrino15 | Programming | 17 | 12-01-2008 00:05 |
| If you have to use dial-up, don't use NetZero | JBotAlan | Chit-Chat | 7 | 18-12-2006 01:39 |
| FIRST in FUTURE | RoboMadi | Chit-Chat | 11 | 10-12-2006 18:23 |
| Ethics 101: To re-use or not to re-use? | aaeamdar | General Forum | 87 | 07-12-2006 19:10 |
