Go to Post Now repeat after me: it is just a game. It is just a game. It is just a game... - dlavery [more]
Unread 28-04-2008, 19:13
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Team Role: Teacher
Rookie Year: 1999
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
2002 CIM specs
I'm looking for specs (dimensions) for the old CIM motors (2002?) that had the gear shaft.
A friend of mine is using them for a project and needs to connect something to the gear shaft they have. I can't find any of the old specs sheets for them. If you have specs, an adapter or a method for the shaft please let me know.
Thanks.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 28-04-2008, 19:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: 2002 CIM specs
It was not an 8mm shaft with a 2mm key. That first came about in 2003, and has undergone slight revision since.
To quote Joe Johnson,
It is a 36 Diametral Pitch, 9 tooth, enlarged, 25 degree pressure angle gear.
Basically, you won't find a mating gear anywhere outside of old FIRST teams or the Atwood Mobile power jack it was original equipment in. I'd recommend just spending ~$30 apiece and getting the new CIMs.
Here's the thread I reference http://www.chiefdelphi.com/forums/sh...&threadid=1457
Unread 28-04-2008, 19:55
Team Role: Teacher
Rookie Year: 1999
Re: 2002 CIM specs
Originally Posted by sanddrag View Post
It was not an 8mm shaft with a 2mm key. To quote Joe Johnson,
Does anyone still have the gear cluster that came in the kit or know where to get one?
Does anyone know of some sort of coupler that would fit right over the gear shaft? Space and size is a premium.
155, teacher: 2011-
Unread 30-04-2008, 11:39
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
Re: 2002 CIM specs
Jeff-
We used to wire EDM a profile that would fit onto the "spline" in order to install a gear on that shaft. That would not take up too much space.
Ken
Unread 30-04-2008, 13:43
Team Role: Teacher
Rookie Year: 1999
Re: 2002 CIM specs
Has anyone tried turning down the shaft and putting a keyway or flat on it? Would it even be possible or practical?
155, teacher: 2011-
Unread 30-04-2008, 13:50
Team Role: Teacher
Re: 2002 CIM specs
You could machine the bore of your gear/hub/etc to fit over the OD of the CIM gear shaft, then drill a transverse hole through both pin them together.
Unread 30-04-2008, 23:52
gburlison gburlison is offline
Mentor
FRC #0662 (Rocky Mountain Robotics)
Rookie Year: 2000
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: 2002 CIM specs
After we disassembled our 2002 robot, I took the 2002 cims and installed them into 2005 kitbot gearboxes. It was the square aluminum gearbox that looked sort of like the AM toughbox. I just slipped the gear over the shaft and tightened the set screw into the gear teeth. We only used them on a prototype drive train for programmers, so it did not see a lot abuse.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 01-05-2008, 09:51
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: 2002 CIM specs
Jeff,
Joe Johnson posted this in http://www.chiefdelphi.com/forums/sh...ghlight=atwood
From McMaster part number: 61005K51
It has a 3/8 bore on one side and a 1/4 inch bore on the other.
I would clamp the coupling to the 3/8 diameter drill rod and then chuck the drill rod in a lathe.
I would gradually open up the 1/4 inch hole until the Chiaphua gear just pressed inside the coupling.
Then I would tighten down the clamp on the 1/4 inch side and viola... ... you've got a nice 3/8 inch diameter shaft to work with.
By the way, I am NOT doing this, so I can only judge what I think I would like to do. Any other folks think this is a good idea or not?
Joe J.
P.S. I am assuming that you want to mate to the 9 tooth gear cut into the motor shaft and not one of the gears on the cluster. Did I assume correctly? JJ
Andy Brockway
Team 716, The Who'sCTEKS
AndyMark CIM Planetary Gearbox Torque Specs Needed KTorak Technical Discussion 4 17-01-2008 18:53
Large CIM specs? Xarda Motors 1 31-01-2007 23:07
Small CIM Gear Specs Joe_Widen Technical Discussion 2 03-04-2006 23:10
Large CIM motor specs ryan_f Motors 4 13-01-2006 21:38
Drill and CIM specs BlacKnight6604 Motors 1 13-01-2004 09:52
