Go to Post Engineering fundamentally comes down to problem solving, and if the students can't get excited and inspired by the problem solving process because someone has spoon fed them a solution, then nobody wins. Give a man a fish, he'll eat for a day. Teach a man to fish, he'll eat for a lifetime. - kevinw [more]
Unread 29-04-2008, 12:22
R.C.'s Avatar
Happy Birthday! R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Best Drivetrain
I am posting this because a rookie team in Davis was having a hard time deciding and creating a drivetrain for their robot. There have been many different types of drivetrains used in FIRST. So in order to help all the rookie teams for nex year, what drivetrain has been the most dominant from the 2005 season and on?
-rc
ps Pictures please
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 29-04-2008, 12:26
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
Re: Best Drivetrain
I would say the KOP transmission with 2 CIM motors per side, driving six wheels via chains. More robots use this than all other layouts put together. My observation. YMMV. Offer not valid in Michigan.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 29-04-2008, 12:29
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Re: Best Drivetrain
6 wheel drive with either lowered center wheels (~1/8") or omnis on the corners. This has without a doubt been the most successful drivetrain in the past and is very simple to build. As long as you can build a 4 wheel drive you can fairly easily add 2 more wheels. If you really want to improve it, add traction wheels such as ifi and a 2 speed transmission. An even better addition is directly driving the center wheels off the transmission shaft so that even if all of the chains break the robot will still be powered. This requires a little bit more work though and most likely precise machining capabilities.
Mentor 2415
Unread 29-04-2008, 12:32
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Best Drivetrain
Specifically, it requires a longer output shaft than any standard transmission will give you.
Usually it's just as much weight to do the bearing blocks for a direct drive setup as it is to do an AM hub with AM flat sprockets with extra chains. Since it's more difficult to do the former, most teams stick with the default method.
GitHub
Unread 29-04-2008, 12:37
Re: Best Drivetrain
My old FRC team has never built a really great robot (sad, but true), but their chain-driven, 6WD chassis with the KOP gearbox has been bulletproof all four of the last seasons. The concerns about breaking #35 chain (in my experience) are exaggerated -- if you don't do anything weird or stupid, they simply won't break before the motors stall out. When you start getting into more exotic choices, stuff starts breaking. It might be worth it if you have a sophisticated robot and build process, but I think most teams would be well-advised to go with a proven drive-train and spend their brain cells on building better game mechanisms.
Unread 29-04-2008, 12:40
AKA: Sean
Re: Best Drivetrain
Direct drive does require modifiying all but the andymark super shifters. Although getting a longer shaft machined is really not that difficult. My preference for direct drive is that even if all chains somehow snap, the robot will still perform just as well since the center wheels are always in contact with the ground. This also makes it slightly more reassuring to use #25 chain since no matter how many chains break the robot will still run. #25 chain saves a ton of weight over #35 and it also only uses 4 chains versus at least 6 in a normal 6 wheel drivetrain. The only thing to remember with #25 and really even #35 chain is to have a way to easily tension the chain. If you can keep the chain tensioned and lined up properly then you will never break a #25 chain.
Mentor 2415
Unread 29-04-2008, 12:52
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Best Drivetrain
Sorry, guys, but you are ALL wrong.
The correct answer is: we don't know.
The game hasn't been released yet. Maneuverability might be key, power might be key. We don't know. We won't know until January.
That said: Rookies should NOT attempt a swerve or holonomic. Even veterans have trouble with those sometimes.
4WD or 6WD skid steer, Kit frame, would be my best advice. Those are really versatile, especially the 6WD drop center. Kit trannies would be recommended, but I'd have to see the game before committing to anything. Exactly what setup depends on the game. Chain drive, due to ease of use. Because this is a rookie team, tensioner of a block of delrin under or over the chain mounted so the chain digs into it a little. While it is possible to get away with not using a tensioner, that's something that only a veteran team or a team with decent CAD/manufacturing ability should attempt.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 29-04-2008, 15:18
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Re: Best Drivetrain
While this may be good advice a good chunk of the time I feel as it may be a little bit of blanket statement. Although I'm sure you had no mal intent.
I have seen very capable rookie teams that would be able to handle making a swerve or holonomic and I've seen many many many veterans who would not be able to pull one off.
Judge your teams capabilities...if a task looks daunting, it probably is...if you think your team may be able to pull it off, go for it. FIRST isn't about winning, its about learning. Go for the design that will knock peoples socks off...who cares if you dont get 2 weeks to drive it around before competition. Thats just my honest opinion.
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 29-04-2008, 15:29
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Re: Best Drivetrain
While I agree with Brandon on most topics, this is one we don't see eye to eye on.
In my experience a fully functioning, simple robot is much more effective and reliable than a figurative time bomb on wheels. Remember that reliability is a part of your scope, as is function. If this doesn't click, think about what you look for in a car. There's a reason Honda and Toyota have risen to the top of the proverbial food chain.
The enemies of scope are time and cost. (FIRST has a third enemy: experience. But that is for a different discussion!)
Broken robots = stressful = no fun = less inspiration
Unread 29-04-2008, 15:55
Re: Best Drivetrain
No one said the robot had to be broken...just because it is more complex, or took more time to develop doesn't mean it is going to break.
I dont know tom, i guess we'll have to agree to disagree here...it seems to me that learning some more complex engineering substance is just as valuable as any other part of FIRST.
Unread 29-04-2008, 16:30
Chris Marra's Avatar
Chris Marra Chris Marra is offline
The Blue Alliance Staff / 177 Alum
no team (TBA / Bobcat Robotics)
Chris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond repute
Re: Best Drivetrain
I have to back Tom on this one, mostly because I think he just has another take on the same issue. Teams sometimes need to make a decision about where they aim to provide the most inspiration to kids - in the workshop through innovation, or at the competitions through empowerment when they see their creation. Sure a complex design is an amazing feat to accomplish and everyone can take pride in it, but how much fun is it if you don't finish it or you don't get a chance to utilize it because your focus was on making it happen at all. If you can finish your design early you get to show kids another very important aspect of engineering - testing and training. If you took any talented driver and told them they would be driving a Wildstang robot for the first time at a competition right after the coders finish testing, they would flip out. Not everyone can take a positive message out of a complex design if they don't pull it off in time or they don't get to use it to its fullest. I don't want to come off saying that winning is the inspirational experience, but sometimes competing needs to take a little more precedence over designing and learning how to tackle a complex project like any robot within the constraints of the competition is something teams ought to consider too. So there is nothing wrong with attempting a complex design, because there is no reason it shouldn't succeed, but teams ought not lose sight of their final goal: to have a competitive, fully operational robot completed within six weeks (without forgetting about their drivers or coders!)
Team 177 - Bobcat Robotics
Unread 29-04-2008, 16:53
Re: Best Drivetrain
Chris/Tom
I agree with you guys, but I think your missing my point. I am not saying to go out and build some ridiculous design...but as a rookie team I feel it is good to set a precedent that you are going to do your best to make a robot that is to your ability every year. Some teams simply cannot machine an entire drivetrain, that is understood...but if a team has the means to make a part of their drivetrain, a little complicated, or innovative, why not?
I think it is important to balance the idea of "being competitive" with learning science and technology too.
I guess what I fear is a team saying, well yeah we could do that, but why don't we just buy this and call it done...
Unread 29-04-2008, 17:51
Re: Best Drivetrain
I don't think anyone is doing that. I just think the drive base aspect of FIRST robots has gotten to a point where it is more economical to "drag and drop" components. Design considerations for "learning" can be made in other areas of the robot.
You have when to hold your cards and when to fold your cards. Take the ace that FIRST has given us and build the kit chassis or a simple 6wd setup with COTS. The time you save will allow you to invest more into your functional designs, which are usually the things that make or break a robot design.
Unread 29-04-2008, 16:36
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
Re: Best Drivetrain
This was probably one of the biggest lessons I took away from this year. Over the course of my FIRST career, my designs have ranged from the super-simple to the super-complex, and everywhere in between. This year was by far the best robot I've ever worked on, and it was also probably one of the simplest. Coincidence? I think not. Everything was simple and reliable, and it worked every time (barring a mishap with a wire and the terminal block). After 4+ years of constantly having to fix things at every event, I had two stress-free competitions, both of which were greatly successful.
The takeaway from all of this: especially for drivetrains, most teams will benefit from something simple and reliable. The less experience and assistance you have, the more critical this becomes! The last thing you want is to spend your whole competition season getting the robot to move. A 6WD chain drive may not always be the perfect drivetrain for every competition, but it's easy, simple, and reliable, and it will always be serviceable and successful for any game. (Until we get that water game, or Dave punishes us by banning all wheels.... )
An addendum on the #25 versus #35 question: I consider myself to be a pretty experienced designer, but I will ALWAYS use #35 for drivetrains. It doesn't matter how well you can CAD a drive base, if your fabrication tolerances are not tight enough, you WILL have problems with #25. I will take the reliability and forgiveness of #35 over the weight savings any day. I've seen too many #25 systems fail due to misalignment to do it any other way.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
  #15   Spotlight this post!
Unread 29-04-2008, 16:58
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Team Role: Coach
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
Re: Best Drivetrain
I have to chime in here as well.
1) There's no rookie team in Davis, maybe they were referring to a rookie team that attended the Davis Regional.
2) Not to stiffle creativity and the thrill to innovate, but for a rookie team or 2nd year team - I highly suggest a robust 6WD setup with kit transmissions (if supplied).
Pic... http://www.travisusd.k12.ca.us/vande...n/DSC05175.JPG
Last year was probably our most reliable drive system (yes - even with banebots). Kit transmissions, chained to a center-traction wheel (kit wheels), the center wheel chained to the front and back wheels. Tensioned with UMHW off-center cams. The whole drive system was put together using nothing more than a cordless drill and a band saw (neglecting the welded frame which could be replaced by a kit frame).
THE MOST IMPORTANT THING FOR A ROOKIE TEAM IS TO GET THEIR DRIVE SYSTEM WORKING BY THE END OF THE THIRD WEEK. Our team was very competitive last year, simple because of it's dependablity and driver practice. Our drive team had over a week of practice before ship.
3) Use innovative ideas to develop a cool manipulator or strategy. There's absolutely nothing more troubling than to have your robot unable to drive.
I think back to the days of 2000, 2001, 2002 when there was no simple drive system that came in the kit. You had some cordless drill motors, transmissions, and skyway wheels that you had to make work. That took our team the bulk of the 6 weeks.
Work Hard, Have Fun, Make a Difference!
drivetrain!!! hiimcristhian General Forum 3 12-01-2008 23:51
Drivetrain Kit Justin Brooks Robotics Education and Curriculum 9 27-01-2007 16:11
Best Matches (best fought not score) ne0x0n General Forum 13 01-04-2005 12:40
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Drivetrain Hawk135 Technical Discussion 3 06-01-2003 22:14
