Go to Post Welcome to the world of pros and cons. - Billfred [more]
Unread 30-04-2008, 23:15
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Re: How much torque can the Dewalt Trannies take?
Originally Posted by EricH View Post
Depends on the application. 3-speed or 2? 3-speed, Dewalt. 2-speed, AndyMark.
I'd go with AndyMark if I was in a time crunch. Very little assembly, if any.
Lets say we were only looking at the Dewalt as a two speed since the person before me said its hard to get 3rd gear to work.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 30-04-2008, 23:47
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
DeWalts are a planetary transmission, and as a result have all the advantages and disadvantages of it. The biggest advantage is the much smaller size of the transmission. This is especially important in less than "traditional" drive designs where transmissions might not have as much space. Non-coaxial swerve systems often are forced to have the motors and any reductions (transmissions) rotate with the swerve modules. If a team were to opt for a multi-speed, non-coaxial swerve system, DeWalts would definitely be the way to go. Of course there's plenty of other scenarios where DeWalts would be advantageous for their size as well, that's just one extreme case.
Being correct doesn't mean you don't have to explain yourself.
Unread 01-05-2008, 01:01
Lowfategg's Avatar
AKA: Tyler Moser
Being that I am new to FRC being from FTC I don't really know the advantages and disadvantages of a planetary transmission (since my FRC team did not play with them). From what I can see I love the idea of them and they seem like they would be very good. But from what your saying the Dewalts are good because of there size.
Unread 01-05-2008, 01:26
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
In short, planetary gearboxes are a much more compact method of getting reductions than standard spur gears, but are far less efficient.
For instance compare the banebots transmission to the AndyMark toughboxes.
http://banebots.com/pc/P80A-nnnn-000...80A-43-0005-R2
http://andymark.biz/am-0145.html
While the banebot's transmissions had other issues in reliability that caused them to be unpopular, the differences in dimensions for gearboxes with essentially the same reduction are apparent. This is magnified even further when comparing a shifting transmission such as the AndyMarks to a DeWalt.
http://en.wikipedia.org/wiki/Spur_gear#Spur_gears
http://en.wikipedia.org/wiki/Planetary_transmission
Unread 01-05-2008, 01:47
Lowfategg's Avatar
AKA: Tyler Moser
Ok thank you. Thats what I thought when I looked at planetary gearboxes.
Unread 14-05-2008, 15:34
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
Simple torsional stress calculation:
I couldn't find my old notes, but here is an example if you are direct drive with a 6" wheel that only the torque is causing stress (i.e. no bending load). The shear stress is equal 16*Torque/(pi*d^3) for a round shaft. So back to our 6" wheel example a scenario might go like this: because you are pushing against an opponent all of your robots weight is on one side and your wheels are slipping. Axle torque is the Normal force (weight) * traction coefficient (1.3 peak from team 494 testing)* radius of wheel 3" or about 500 in*lbs (132lbs*1.3*3in). You throw this into the equation above with a 5/16" diamter shaft (I think that is the dewalt output shaft minor diameter) and you get ......... a stress of 83 KSI. So that people get some perspective mild steel (1010) is around 26 KSi (hot rolled) 44 KSI (cold rolled). If you made your direct drive output shaft out of that material you would probably be able to drive your robot around just fine since the loads would be split with the other side. You wouldn't break a shaft until someone hit you. If you went with something like 1050 cold rolled you would begin yeilding a shaft when pushed. Do this a few times and eventually you will break a shaft. For fully reversed torque, it is common to use a factor of safety around 2 when you want to make sure you won't break that part. 170+KSI steel tends to be special grades of heat treated 4130.
Moral of the story for robotics: If your design starts requiring above 50KSI material you either want to rethink your design or be very careful with your design AND your material selection. I have often seen failed designs where the designer was designing for 1010 Cold Rolled (44 KSI), and part was made with 1010 Hot Roller (26 KSI). What was once a factor of safety of 2 goes to 1 and eventually the shaft fails.
This is a very simple version of a much more complicated shaft. In reality the D-shaped shaft has a stress concentration factor that makes the actual stress a lot higher than the what you would see in a round shaft. There are a lot of good books out there about machine design The one I have is "Machine Design: an integrated approach". If has a ton of examples that are easy to follow once you have a good understanding of what Stress and Strain are and how to apply loads. If you don't know what Stress and Straing are, read the book from cover to cover. This was the book for Purdue's Machine Design class while I was there. While figuring out the exact load scenario is best, simple calcs like the one above will tell you if you are in the ball park. I tend to use calculations like that to sort out should never fail, might fail, or garuanteed to break.
Unread 27-05-2008, 17:44
Justin Ridley Justin Ridley is offline
FRC #0118 (Robonauts)
Rookie Year: 1998
Justin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond repute
Send a message via AIM to Justin Ridley
A quick note on the Robonaut V6. We did put six motors through a dewalt in '07 and I was completely shocked that it handled the torque. It's important to mention that we did see a couple sun gear failures that year that seemed to be caused by hard impacts (sudden stopping of drive). We made the design easily replaceable since we knew we were pushing the limits of the gear box. Overall I think it was as reliable as most (but not all) drivetrains that year.
Another important point... we were only running the drive in one direction. If the gearbox had to withstand the back and forth seen with tank steer I have little doubt it would have failed.
-- Justin Ridley --
20 years
27 --> 221 --> 857 --> 118
Unread 03-06-2008, 02:03
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
What about using omni's in the front and putting a dewalt to each of the 4 wheels left. Direct drive or shaft, sprocket and chain to the wheels??
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
How much of our wheel used for the shooter can be exposed? waialua359 Technical Discussion 4 14-02-2006 13:27
Servos - How much can they lift? John JediMaster Electrical 23 31-01-2004 19:03
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
How much can the window assembly lift? archiver 2000 9 23-06-2002 22:59
How much code can an IFI controller handle? Larry Barello Programming 7 10-02-2002 19:06
