Go to Post So go out and learn something new, even if it is old. Co-operate in this and you'll get much more out of it. Cheat and you are only cheating yourself. - ChrisH [more]
Unread 30-04-2008, 12:44
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Master Gearbox's
There have been many gearboxes made in the FIRST building season. What gearboxes do you use and what are the pros and cons. Also one cim or two cims, fps, and reliability. This thread is created to help veteran and rookie teams. Also this helps organize all the gearboxes.
thanks
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 30-04-2008, 13:16
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Master Gearbox's
2 Andymark Toughboxes
2 CIMs in each
18 Tooth Output to a 22 Tooth Wheel Sprocket
~7 FPS through 6" wheels.
Our gearboxes were loud. We will probably be taking out one of them and disassembling to see if something is wrong. They have been very reliable though. They haven't broken down ever.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 30-04-2008, 13:20
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
I strongly approve of AndyMark products. I used some Gen 2 shifters last year, Toughboxes this year, and I'm planning on ordering SuperShifters for an offseason project (and next year, most likely). I've never had a problem, and they've all been rock-solid. For ease of use and reliability, AndyMark is hard to beat.
As far as motors go, 2 CIMs per side is my standard. I've done it ever since they added the additional CIMs to the kit in 2005, and it's definitely the way to go.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 30-04-2008, 14:20
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
For the last 2 years, we have bought the replacement parts for the Andy Mark 2 speed gearboxes and then made our own gearboxes from those. We tend to integrate the gearbox into the frame, use 2 CIMs per side, and direct drive the middle wheels of our 6 wheel drive base. We go with AM because most of the hard work hex broaching the gears and making the dog pattern is already done. And everything just works.
Off the top of my head, I would guess 6fps and 11fps.
Unread 30-04-2008, 14:32
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
330 and 1135 use AndyMark. 330 uses the Gen 2 shifter, pneumatic, while 1135 used the Toughbox last year.
330: 2 CIMs, 6WD, not sure of speed, no gearbox problems have ever taken them out of a match. (Chain problems have only done that twice in the last 6 regionals/championship.)
1135: 1CIM, 4 toughboxes, mecanum drive, too slow (our fault--I should have had the team switch the Toubox output sprocket with the wheel sprocket, or something like that.) No gearbox issues.
Pros: Unless a rule changes, guaranteed legal, very reliable, and easily repairable if you do somehow break one. Also good tech support.
Cons: A little pricey, but it's comparable to doing it yourself. So that evens out.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 30-04-2008, 15:13
Arefin Bari's Avatar
Arefin Bari Arefin Bari is offline
AKA: Ari
FRC #0108 (SigmaC@T)
Arefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond repute
Send a message via ICQ to Arefin Bari Send a message via AIM to Arefin Bari Send a message via MSN to Arefin Bari Send a message via Yahoo to Arefin Bari
It all depends on what you are comfortable with. Team 108 and 1345 both used AndyMark Gen1 and planning on using parts from it next year as well.
Download the JVN calculator and look under the first tab called "Specs." It has all the information you would need about the motors that are supplied in the kit. It also shows specs on stall torque, stall current, and free current when you combine motors together. And of course you can easily calculate the speed of your drive train, rotary mechanism, linear mechanism, and intake mechanism as well. It's a useful tool. Download it from here.
Unread 30-04-2008, 16:33
CraigHickman
Posts: n/a
Custom. You get what you want, how you want it, in what shape you want it, how fast you want it, and so on. It's more expensive, but I've found it to be worth it in the end. You end up (in my experience) with a lighter package, and you know EVERYTHING about it, so maintenance is pretty simple.
Oh, and you get the bragging rights of a custom system.
EDIT: If you have ANY kind of a budget, I can't suggest anything other than Andymark gearboxes. They're reliable, proven, light(ish), and the best bang for your buck. They're not as durable as I'd like them, but I personally prefer bulletproof (figuratively) robots.
Unread 30-04-2008, 17:00
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
In MY experience, the AndyMark products have been fantastic. I also prefer bulletproof robots, and the AndyMark gearboxes have delivered again and again.
We've bought AM stuff before, and we'll do it again. They should definitely be the first place any mechanical designer looks.
Regards,
John
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
Unread 30-04-2008, 17:23
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
With the same design constraints they have to deal with, I doubt many people in FIRST could build a better all around gearbox. If you're using them right, the AM gearboxes are extremely unlikely to fail. I'd be very impressed if anyone could top them.
Unread 30-04-2008, 17:34
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
AndyMark, all the way. You can use them as-is or use the internals and replacement parts as the besis for a custom design. More importantly, in my opinion, is that during that 6-week crunch, you can concentrate on designing the rest of your robot and integrate a finished product into your design (made even easier with their pre-made 3D CAD models).
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 30-04-2008, 17:49
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Regards,
John
I'm with John. AM gearboxes qualify as bulletproof in my book.
There is no better bang for your buck. End of story.
2001-2004: Team 100
2006-Present: Team 254
Unread 30-04-2008, 17:50
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
I've never had any problems with a properly assembled AM gearbox. We've used them this year and after 2 regionals and the Championship (37? matches or so) and a weeks worth of beatdowns we've never had a problem with them. One of them is kinda loud but it sounds cool so we never really cared. If you're ever thinking of using a custom gearbox I would look at AM first. Their products are constantly being revised and have been tested for seasons at this point.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 30-04-2008, 18:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
We like to make our own gearboxes so we can get the exact ratios and mounting configuration we're after. However, we are still conscious of time and budget constraints and limited resources. This year we used numerous individual AndyMark gears in our drivetrain and spool gearboxes. They're cheaper than Martin gears, there are no heavy hubs, and they already have a hex broached bore (or in the case of the dog gears, are all ready to go).
Unread 01-05-2008, 13:06
R.C.'s Avatar
Any pics?
R.C.
  #15   Spotlight this post!
Unread 01-05-2008, 13:31
Rookie Year: 1999
Here is a shot of ours. Nothing too special. Some AM gears on either custom or AM axles, depends on the axle, and some laser cut 1/8 " aluminum side plates held together by spacers.
Transmission
Old globe motor gearbox's allowed? Lavapicker Motors 7 26-01-2007 19:37
Master Code 11? SteveO Programming 5 22-04-2005 19:48
Master Code? HolyOne207 Programming 4 12-01-2005 22:32
Gearbox's Gadget470 Motors 2 04-12-2002 22:16
