Go to Post You heard it here first folks. The robot will definitely need wheels and will probably have an arm. - DampRobot [more]
Unread 30-04-2008, 22:03
thatmorman's Avatar
thatmorman thatmorman is offline
David
AKA: David
FRC #1510 (Wildcats)
Team Role: Leadership
Rookie Year: 2007
thatmorman will become famous soon enough
Send a message via AIM to thatmorman Send a message via MSN to thatmorman
2.5 inch cims of 2008
is it just me or were the cims from this year a little slower rpm then that of last year? we use a 12 to one ratio and it seemed like we were about 2 fps slower than our bot last year...
David Cobbley
Captain & Mechanical Leader
Team 1510
I <3 inventor & anyone in FIRST
Unread 30-04-2008, 22:21
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: 2.5 inch cims of 2008
There are a lot of variables that factor into this. Did your drive train change at all? I didn't notice a huge difference. Maybe it was just a ratio difference between your drive sprocket and your wheel sprocket.
-Vivek
"we don't build robots, we build people"
Unread 30-04-2008, 22:27
CraigHickman
Posts: n/a
I noticed my robot getting FASTER. But then again, I removed 5 pounds of rotational mass from each side....
Have you checked all the wiring to make sure you're not losing any current on the way to your motors? Long lengths really add up...
Also, how heavy are all your moving parts? If it's lighter than last year, you should be faster. If heavier, then you'll be slower.
Unread 02-05-2008, 00:51
thatmorman's Avatar
David
AKA: David
Rookie Year: 2007
well even just when we hooked up the cims to a battery they seemed slower. there were others on my team who think they noticed a change too. im just trying to figure out if i was imagining things... haha, i know that you couldn't use last years cims, they had a different number on them, but idk.
David Cobbley
Team 1510
Unread 02-05-2008, 01:03
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We really couldn't tell, mainly because 2 of our 4 motors were spares left over from last year!
Unread 02-05-2008, 02:52
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
Team Role: Coach
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
ya what do you mean we couldn't use CIM's from last year??? I've never heard of that... too late now either way i guess.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 02-05-2008, 02:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
We found that CIMs that have repeatedly been overheated get significantly weaker and slower.
Unread 02-05-2008, 03:14
thatmorman's Avatar
David
AKA: David
Rookie Year: 2007
they were telling teams at the Portland regional that had used their extra cims from last year to change them out for this years or they would be disqualified... it was the dumbest thing ever because multiple teams had used previous years motors... im not exactly sure what all happened, but thats what the inspectors were telling us...
David Cobbley
Team 1510
Unread 02-05-2008, 03:17
CraigHickman
Posts: n/a
Fun fact: The only difference between the motors is the serial number. We ran both on a bench test, and both were within acceptable factory variations. I don't understand this rule, but it IS the rule, so you SHOULD follow it.
Unread 02-05-2008, 08:16
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Well, unless you honestly don't know which one's a 2008, 2007, 2006 because they all came out of the jumble in the cardboard box in the shop marked CIMs.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 02-05-2008, 12:24
MrForbes's Avatar
AKA: Jim
This got me curious...so I looked it up...and it appears to me that <R58> implies that you can use spare motors you purchased the previous year, but you cannot use motors that were actually used on the previous year's robot.
Interesting.
Unread 02-05-2008, 13:15
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Yes, when motors do get hot, they lose a little bit of their magnetic force. Thereby losing power.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 02-05-2008, 13:31
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
<R58> Motors, pumps, and, Robot Controllers from previous robots shall not be used in addition to those provided in the 2008 Kit Of Parts. They may be used as direct one-to-one SPARE PARTS for those provided if the provided part fails or is damaged. They can only be used if they are identical to the part being replaced.
So yes, the inspector was correct as Jim pointed out. Last year's motors, although identical, could only be used as spare parts replacments. GP dictates you follow the rule and inform the RI when asked. With the large influx of rookie teams and teams on a budget, we must maintain this type of rule.
Teams were reporting to me a greater direction bias than we experienced in that past with these motor.
Heat does change the power curve by either damaging the armature wiring (shorting some of the turns) or by altering the magnetic structure. Extreme heat may also damage the brush assy and warp the metal internal to the motor. Over time, an improperly supported shaft with significant side load, will also damage the bearings. CIM motors are not intended to have large side loads, the bearings are only bronze sleeve.
Al
WB9UVJ
www.wildstang.org
________________________
CIMs? fishgurl General Forum 3 15-02-2008 17:47
80 inch diameter? Pneumaticsman Technical Discussion 4 15-01-2008 08:54
CIMs brennerator Motors 10 26-01-2007 10:22
2 CIMs -- practical? Joe G. Motors 15 23-01-2007 15:32
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
