Thread Tools |
Rating:
Display Modes |
.ipt to dxf? to CNC machines?
How do I get an ipt file to work with a CNC machine? I have a few aluminum parts that I've designed for use on the chassy, how do I export the ipt file so that the CNC mechanic or computer can read its dimensions?
I have more than a dozen parts, so dimensioning them would take a while, the CNC mechanic person would also have to design it back so he can run it on the CNC. Is there a way to convert the ipt file to a standardized format so that I dont have to dimension them, whoever opens the file, all dimensions will be available to them Via computer. Is there even such a thing? Last edited by Generalx5 : 06-05-2008 at 00:01. Reason: syntax error! |
Re: .ipt to dxf? to CNC machines?
I use SolidWorks, but here is the general process on how parts go from a CAD model to a finished part via CNC. (It's good to keep the entire process in mind, even if you are just designing the parts).
Also, in addition to the part models, it is always useful to submit a dimensioned drawing of the part, showing all the critical dimensions and their tolerances, as well as the number of parts needed, the material required, and any other part features which are important to keep in mind while manufacturing the part. I'd suggest that if you don't have any experience in this field, ask for a tour of a CNC machine shop, and ask lots of questions along the way about the process. You'll learn a lot, and it'll most likely make your part designs even better. |
Thanks Arthur!
One more question, when I save as to a dxf file in inventor from an idw file, what actually is happening to the new file created? When I found it, it had been zipped, and when I opened it, 2 or 1 text file appears, inside is a mass amount of code....not programming code, looked like random segments. When someone outside opens it properly with a dxf opener, are they able to see the model dimensions? will it be in 2D or 3D...If I didnt dimension the idw file to begin with, would the dxf file be dimensionless? |
Usually, as long as the DXF file is exported at a 1:1 size ratio, the dimensions can be found from the model itself. |
What version of Inventor are you using I know that when i export files from inventor 2008 for use in CAM programs it creates a file that is just a .dxf extension file also when you export the 2d drawing you want to make sure that you delete the the border and the box with the part name and that sort of stuff the person making the G code for the mill will thank you also i would make sure that the drawing has not been dimensions because it makes the person running the CAM program delete a lot of stuff and as long as the part was in a 1:1 ratio when you put it on the idw you should be fine |
Thanks, I will find something that can view the dxf file right after this post.
I don't understand about the idw to dxf transition. Is the Dxf file a 3D model? how does it "rebuild" itself form a 2D file such as the idw format. Thanks for mentioning about deleting the boarders and dimensioning it, would it be okay if I had several views of the model? top view, front view, iso metric, and cutaway view. Thanks for the tips! Oh right! I am using Autodesk Inventor 10...on a vista, with a really nice virtual PC tool =D Thank god! Last edited by Generalx5 : 06-05-2008 at 23:44. Reason: Oh right! I am using..... |
Sorry for not saying, the actual answer I still don't know, Im looking for CNC shops that are open to public/commercial contracts. with no minimum order quantities. So....I hope that answers your question, Im guessing it would be something common. Mastercam or Gibbs. Are there any significant differences I should take note of?
#11
I would look here
http://www.chiefdelphi.com/forums/sh...ad.php?t=59985 and http://www.chiefdelphi.com/forums/sh...ad.php?t=28982 Last edited by Jeff 801 : 07-05-2008 at 18:30. Reason: more info |
#12
Im courious to how much one would have to spend...on average for a custom part to be made on a CNC.
What would the cost be for something like a custom motor mount bracket. Complexity? Chamfered edges, not so complex. I will need 6 of these. Know the cost? |
#13
If you post some photos of the parts in question, it would be easier for us to make a better assesment of the part. |
#14
Heres a look at the right side bracket. its not completely finished...75% done.
See attached pictures. Thats a 12" x 5" base with a motor mount on the circular portion of it, and a support bracket on the other end. Last edited by Generalx5 : 09-05-2008 at 13:15. |
| Intelitek CNC Motion - Virtual CNC Machines | Kingofl337 | Programming | 0 | 19-03-2008 11:29 |
| CNC Machines | DEAL234 | Technical Discussion | 17 | 07-02-2007 16:30 |
| What machines are you using? (CNC, lathes, mills, 3-in-1 machines?) | MrB | Technical Discussion | 17 | 03-11-2006 11:55 |
| To CNC? Or not to CNC? | phrontist | General Forum | 21 | 26-03-2004 13:45 |
| Inventor (*.ipt) -> Dxf | patTeam241 | Inventor | 5 | 16-02-2004 23:09 |
