Go to Post anything that breaks a kitbot frame is probably breaking most custom frames of similar weight, too. - dtengineering [more]
Go Back   Chief Delphi > Other > Math and Science > NASA Discussion
Unread 08-05-2008, 08:35
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Cold-gas propulsion test
The Common Modular Spacecraft Bus (CMSB) is a spacecraft concept being developed by the NASA Ames Research Center in Mountain View, CA. The CMSB is being designed to be compatible with lunar surface, Mars orbit, asteroid surface, and Earth orbit missions. The system is relatively unique, because it uses a cold gas propulsion system rather than a hot combustion rocket. This only allows a few seconds of flight in Earth gravity, but that is sufficient to demonstrate the principles of the propulsion system. It also drastically reduces the time required to recover, refuel and prepare the CMSB for repeated flights. Traditional rockets may require weeks or months to refurbish and refly, while the CMSB testbed can be reflown within an hour. This video shows some of the CMSB hover flight tests from late 2007 and early 2008. I thought some of you might be interested.
-dave
(I also must commend the flight team on their choice of wardrobe, as can be observed in the second scene. )
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
cold cathodes w/ OI Doney_585 Control System 4 14-02-2007 00:04
I'd like to contact a cold chamber maker for transmission test. sanparam Kit & Additional Hardware 3 24-11-2005 13:53
Cold Electricity? Gadget470 Electrical 16 25-08-2004 13:31
Helicopter propulsion archiver 2001 20 23-06-2002 22:59
Cold in a Can archiver 2000 8 23-06-2002 22:17
