CIM direct drive
Hi,
I was wondering how I would use a CIM motor in a direct drive application to directly drive a sprocket on the CIM. The CIM is keyed, but it looks a lot smaller than i thought it would be. What size key is on the CIM, and can I buy a sprocket that is already keyed? I don't have tools to key it. Thanks |
Re: CIM direct drive
it's a 2mm keyway, and the only place that would sell them would be AndyMark, but im pretty sure they only sell gears with 2mm keyways and not sprockets.
The CIM motor shaft has a 2mm keyway.
What size/material sprocket are you looking at? Unless you are using a metric sprocket, you may be a little hard pressed to find a stock imperial sprocket with a metric broach. Edit: Cory beat me by three minutes... |
Mcmaster has a 8mm sprocket (item 2302K1). also they have 2mm keyway (item 90457A100) though the sprocket is unfinished, so youd have to either cut your own keyway into it or send it somewhere to do so. also its a metric sprocket, and I dont know how ISO and ANSI chain play together.
though if you had the abilities to cut out a keyway and bore it, you could just go with a small ANSI sprocket, and custom bore it and key it. why would you want to direct drive it though? |
Well, I am doing this apart from my team, and dont have large funds to spend. I wanted to go with a route that didnt require me to have to purchase a transmission, but I think i may have to now.
NOTE: I am not completely sure this will work. We did something similar and didn't notice a problem, but you never know. Maybe somebody with more knowledge can help me.
In 2006, we took an ANSI sprocket and wrapped the CIM shaft with some tin to make it close enough to the same size as the ID of the sprocket so the sprocket would spin fairly true when mounted. We then used the setscrew to hold the sprocket on. The sprocket definitely wobbled when we turned the CIM on, but the number 25 chain never fell off. So it works, but is not a very elegant solution. Thinking back on it, another way would be to take a sprocket with a smaller hole, like a 5/16" bore sprocket, and then bore it out to the size of the CIM shaft. Then, run the set screw into the keyway of the CIM. I am pretty certain that the CIM doesn't produce enough torque to make the setscrew fail. Does someone else know if that is true? |
yeah i'm not sure about this i do not see the chain taking the speed of a cim well unless you have perfect tension and even than it still may not work so well
now a belt there would would work very well here they can take that speed very well |
Furthermore the only way to release the loctite is heat. I melted a bit off one of our Delrin sideplates the other day trying to break a stubborn one free. We hate setscrews and figured this was probably one application where they might be OK. Lesson learned-never again will we rely on them. |
I dont know what you plan on using it for but my guess is that you wouldnt be able to gear the CIM motor down to a reasonable speed simply with sprockets. You can get a Toughbox from AndyMark for cheap.
#10
i am not sure what you really want to spin at over 5000 rpm's but I believe we did this on our poof ball shooter from AIM HIGH. It wasn't all that perfectly successful but we used a three piece jaw coupling I think.
It was some type of flexible disc coupling. It is hard, running the CIM directly like this, to get much acceleration (read torque) ... it took awhile for our shooter to come up to speed and one of its problems was that as we shot the balls it would decrease speed and we would have to wait to come back up for proper trajectory. If you anticipate doing a direct drive of the CIM for a wheel drive system That would not be a good idea... I don't think that is your application though. thanks R |
#11
Your best solution is to get an ANSI sprocket with roughly the right diameter hole and put a pin through the sprocket and CIM axle. This is fairly easy to do, but drilling a hole through the CIM axle can be tricky.
I would not recomend attaching sprockets, gears, whatever to the CIM with just set-screws. The CIM produces far to much torque for those methods to work. |
#12
I think you are right Cory,
We used the aluminum one I believe ... the AL.. It was an interesting mechanism. Originally it was geared down... When we found out it didn't have enough speed we made the change to direct drive.... and forgot that we were using an IGUS bearing on the other end of the shooter drum.... it failed.... Just like they told us it would at intermittent speeds above 2000 rpm The IGUS engineers are really good at helping you out when you have "alternative" uses for what their parts are designed. They are invariably correct when they tell you not to use it for that. that makes sense... its a German company.... good engineers the Germans.... |
#14
Keep in mind that 6.35mm pitch roller chain is the same as #25. You may have an easier time finding parts with a metric bore if you use the metric number for pitch.
#15
| Wheel direct drive | molly | Technical Discussion | 15 | 25-01-2008 00:32 |
| your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors | waialua359 | Motors | 11 | 14-12-2007 04:29 |
| Help! Direct Drive Issues | roberthan | Motors | 16 | 21-09-2006 09:33 |
| pic: 1097 Direct Drive 01 | Anthony Kesich | Robot Showcase | 16 | 13-09-2005 22:33 |
| Direct drive or Chain? | Suneet | Technical Discussion | 32 | 27-03-2003 23:00 |
