#16
Re: pic: Looking for Info/Parts
Andy,
You are right, that is the drill motor from the smaller drill. I found the specs in the 2000 robot manual if you need them. Stall at 114 amps, similar problem with the need to keep speed up to cool the motor. The locking/anti-back drive pawls in the transmission produce serious problems for the housing if not removed. |
#17
I just took one off an old robot. Motor, gears and braket. If you were not so far away I would trade with you. All I have is the dimesions document http://www.team1322.org/documents.htm
#18
Hmmm.... for a 30 lb with low funds is somewhat of a dillemna.
Poor quality parts will break, and you will be frustrated and wish you had just done it right in the first place. I've never built a 30, but I think two small CIMs would be a decent power source (although, compared to more expensive motors they have a poor power to weight ratio). |
#19
If I remain conservative, and my robot is destroyed, then I won't be losing very much - capisci? CIMs seem like they might be a reasonable alternative. If I use the NBDs approach I might be able to keep the weight down. Thanks everyone! |
#20
go with banebots, you wont be disappointed. When Greg Needel and I designed his 30, we used 4 on it for the drive, and man it was powerful!
| Looking for current Linux Info | sparrowkc | Programming | 4 | 06-01-2008 20:34 |
| Duel Info - Robot Parts for Ghana Collection | Mr MOE | Off-Season Events | 0 | 24-09-2007 07:31 |
| Looking for White papers and other useful info | Japper | General Forum | 6 | 12-04-2007 11:43 |
| looking for a bunch of teams for scouting info. | kjohnson22002 | Scouting | 17 | 15-02-2004 17:51 |
| Looking for Teams Info | Ellery | General Forum | 0 | 01-02-2003 15:41 |
