4 inch wheels
Can anyone tell me different places to get 4 inch wheels by 2 inch. Also where to get blue roughtop and wedgetop tread.
Thank you |
Re: 4 inch wheels
You can get 4"dia by 2"wide wheels from IFI, you can also get 4" wheels from Andymark not positive about the width.
http://www.ifirobotics.com/robot-traction-wheels.shtml But as far as blue roughtop (nitrile is the name) just search for "incline conveyor belting" on Mcmaster.com and you should see it. Select the Nitrile roughtop for the "blue" style. And i don't know if anyone makes nitrile wedgetop. 3"wide (thinnest available) nitrile roughtop part number: 5994K851 hope i helped Last edited by Aren_Hill : 17-05-2008 at 20:09. |
Re: 4 inch wheels
Re: 4 inch wheels
yeah we just bough a strip of 4" wide nitrile and used that after slicing it up
Re: 4 inch wheels
Thanks for the help, any other wheels?
Re: 4 inch wheels
Make em. Much more satisfying, educational, and expensive. But in the long run, I've found my custom wheels to be better tools to show off to potential employers, friends, and other random people.
Re: 4 inch wheels
Re: 4 inch wheels
Banebots just came out with some new wheels, apparently. http://banebots.com/c/WHB
$14 will get you a 4" wheel with whatever durometer you want (30, 40, 50) and hub to mount it on a typical keyed shaft. They also have a wide hub so you can double up two of the wheels. These look really neat, has anyone played with them yet? EDIT: you can also just get a keyed wheel for $5! I really want to try them out. Last edited by s_forbes : 18-05-2008 at 10:56. |
Re: 4 inch wheels
Our team has had great sucess using the NPC Robotics wheels. They are simalar to colsons, however come ready with a .5" bore w/ 1/8" keyway. We personally use the 6" variety, but (correct me if I'm wrong) team 148 used the 4" wheels this year on their swerve modules.
You can get them either at: NPC Robotics Robot Marketplace Both sites have them for $19 a piece, which from what I have seen, is nice a cheap! Good Luck. -Chuck Last edited by Chuck Glick : 18-05-2008 at 11:03. |
#10
Re: 4 inch wheels
Those banebots wheels look like an amazing deal if they are decent quality. I am going to try to get some this summer to use on a prototype drivetrain. If they end up working well they will be a much better deal than even the colson variety.
As a side note we used the colson wheels from robotmarketplace that come keyed and they were flawless however for $7 for the banebots wheel it is a much better deal. |
#11
Re: 4 inch wheels
Depending one which wheels from BB you get, you will have different amounts of grip and wear. The 30A will be "grippyist", but wear the fastest. The 50A will be the one that has the lowest grip (of the BB wheels) but wear slower. The NPC wheels are use a 70A durometer rubber. So ALL of the BaneBots wheels will have more grip, but wear faster as well. This could also lead to eventual wheel changes on the BaneBot wheels if they wear too quickly for your liking, which could end up making them more costly than the NPC in the end. -Chuck |
#12
Re: 4 inch wheels
That is very true about the hardness of the wheels. I would have preferred for the colson wheels to be a bit grippier so perhaps the banebot wheels at 50A will be just right. Also you could replace each wheel 3 times for the price of one npc wheel. Just a thought.
| where to but 6 inch omni wheels | jpyro | Technical Discussion | 3 | 12-01-2007 23:47 |
| 3 inch Mechanums | CraigHickman | Inventor | 1 | 21-09-2006 19:18 |
| Skyway 8-Inch Wheels: What A Drag | Rick TYler | Technical Discussion | 9 | 31-01-2006 17:51 |
| Going over 6 inch step with 12 inch wheels | Joe P | Technical Discussion | 25 | 12-04-2004 11:15 |
| We NEED 8-inch wheels and programming help | archiver | 2001 | 7 | 24-06-2002 00:29 |
