Painting
I thought about how cool our robot would look if we painted it. And then i realized how bad it would look at the end of the season. We're always adding new parts on. Taking things off that don't work. Redisinging. Not only would the mix-and-match look terrible. But i look at all the scratches on the robot and i realize that about 40-50% of the paint woul be scratched off. It would look like it went through hell and back.
Re: Painting
Take a look at some teams who have painted their bots, and ask them how they do it. Some examples come to mind: 254, 233, and others. I know 254 uses powder coating, which isn't exactly painting, but the same goal is achieved. Besides, as long as you do your CAD work before building, you shouldn't need to make last minute changes, right?
Re: Painting
paint the bot, make it look cool.
then when the season is over you can demo it somewhere and use it to tell a story of your team experience by using the bot as a visual aid. |
Re: Painting
Instead of painting it, Fondy Fire creates side panels for our robot, which provides places for our sponsors and creativeness to be expressed. The panels are so light, that weight is not an issue. Here's a picture of our 2007 + 2008 robots.
![]() ![]() They look very cool. oh, btw, here's the business that of which we get them printed at. (It's very nice of him to allow us to use the machines... ) He also allows us to print our banners in our pit.http://www.psigncrafters.com/ |
Re: Painting
You'd be surprised actually. I believe 330 paints their robots, after Atlanta their robots still look good. I'd still prefer powder coating or anodizing over painting though.
Powder coating is where they blast a part(s) to get a new, clean layer of aluminum. Afterwards they spray and epoxy based powder on the part(s) and then bake the epoxy in an oven. The end result is a nice, glossy finish to the part(s). While it's easy to get small micro scratches on the surface, it is pretty resilient to major scratches. We've powder coated both our '07 and '08 competition robots and after the season's over you can't really see the scratches unless you're examining the robot up close. |
Re: Painting
We spray paint everything (except extrusion) on our robot either MOE Green or Black. We don't have the equipment in shop for powder coating (although we could probably send parts off to have it done). The paint holds up very well, especially since bumpers have become the norm. Our primary spares are usually painted, as well as any Fix It Upgrades. Even in the MOEhawk year when we routinely broke the wings, we had tons of panted spares. In previous years when the paint has scratched, we have touched it up with Sharpies and nail polish.
I wish more teams would paint/powder coat their robots. Bumpers and side panels are great for adding color but there is something special about seeing a robot that is saturated with color. It stands out and becomes part of the team identity. It gets a little monotonous watching a bunch of bare aluminum robots driving around (especially before bumpers). Last edited by The Lucas : 17-05-2008 at 22:06. |
Re: Painting
"When I am working on a problem I never think about beauty. I only think about how to solve the problem. But when I have finished, if the solution is not beautiful, I know it is wrong." - Buckminster Fuller
I love this quote, as it perfectly sums up my design philosophy. However, I define "beautiful" in the scope of engineering as to mean not only cosmetic eye-candy, but also an incredibly efficient or minimalist solution. A Segway is a beautiful machine, the Millau Viaduct is a beautiful bridge, the Audi TT is a beautiful car. You'd be surprised at how easy it is to make your robot look a lot better with only what I call the "extra 10%" - if you are going to do something, then put the extra 10% effort in up front and make it work right and look good the first time. Here are a list of ways to make your robots look much better: Spray Painting: While spray paint on any exposed metal surfaces can and will scratch easily, on plastics (especially polycarbonate), spray painting on the inside face works really well. You can also do layered painting to make color gradients; and by masking off parts of the Lexan you can do all kinds of nice paint schemes. If you are going to spray paint any metal parts, be sure to sandblast them first if you can. This will remove all kinds of grime and impurities from the surface, and it'll provide a good base to start off of. ![]() Sandblasting: Once you are done machining all those aluminum parts, wash with acetone and sandblast 'em. When you are done sandblasting, wash them a second time with acetone and then spray them with a clear coat to protect the nice sandblasted finish. ![]() Vinyl Cutter: Design your team and sponsor logos in any vector-editing program (such as Adobe Illustrator), and export them to the application which controls your vinyl cutter. From here, you can have the vinyl cutter basically cut out huge stickers in the shape of your vector files which you can stick to anything flat. Polycarbonate is a good choice for vinyl. ![]() Plotter: If you prefer Photoshop over Illustrator, then design large side panels for your robot using any image editing program of your choice. Then with a wide-format plotter, print them out. From here, either you can laminate the panels (I suggest the thickest possible lamination, as the thin ones can easily tear on FRC robots), or glue them to the inside of thin polycarbonate sheet. ![]() Powder Coating: This is my personal favorite - so much so this summer I'm building my own powder coating oven (3' wide x 2' high x 6' long - e.g. large enough to do full-length arm/elevator or a complete welded robot frame) for powder-coating parts in-house. Powder coating is simple: clean the parts really well (sandblasting works), spray the electro-static powder onto them, then cook them in an oven to cure the powder. It's safe, environmentally friendly, and the finished parts are moderately scratch resistant. The only real downside to powder coating is that it typically adds about 0.003" to all parts, although you can "block off" sections of the finished machined parts to prevent powder from going into bearing holes and the like. ![]() Anodize: Anodizing is a great way to protect your parts and have them look sweet in the process. I wouldn't suggest doing this in-house, unless you have a chemistry teacher involved with your team, as I wouldn't really recommend storing the kinds of chemicals involved here in your robotics shop/lab/classroom. Anodizing is a chemical process in which the parts are first cleaned, then etched in a caustic solution, then desmet, then anodized in sulfuric acid, then dyed in the color, then sealed in a heated solution. Anodizing typically adds up to 0.001" onto the parts. |
Re: Painting
Powder Coating for the win!
We would never go back to anything else. No anodizing in Hawaii, so havent really explored that yet. We are looking into chroming. 254 has shown that it can look cool! |
Re: Painting
..our team kind of goes by the rule if it looks pretty it doesn't work well.
of course there are always exceptions to this but for the most part our little rule has been right... |
#10
Re: Painting
We use Tie Dye over thin lexan panels for the robot and then Tie Dye (paint)the bumper material before assembling the bumpers.
#11
Re: Painting
------------------------------------------- *Stroker McGurk was a cartoon character drawn by Tom Medley, he appeared in Hot Rod magazine all thru the early years |
#12
Re: Painting
If the exceptions outnumber the rule, it's time for a new rule. Oh, and the logical corollary is: If it doesn't look pretty, it does well. This is not the case. I would say that your team is an exception, not a rule. One note on 330--it has happened that the color scheme is reversed. Sometimes when that happened, a coat of clear anodize was applied before the yellow paint. We also liked to keep the painting area away from the work area by about 50 feet or more. |
#13
Re: Painting
We have our robot anodized.
One of our sponsors is a local machine shop, and when they get their customer's parts anodized black or gold, they will add our parts to the mix. I think anodizing looks really cool, but you have be careful because the shiny metal really shows up if you scrape deep (we had to sand everything before anodizing). We didn't have a problem with scratches . |
#14
Re: Painting
We set aesthetics as one of our design priorities at the beginning of the season, which meant we had to work especially hard to have all of the parts ready in time to send them to be black or gold anodized before ship date. We built and analyzed a prototype robot so that we had greater confidence that we would not have to make many changes to our final, anodized robot. |
#15
Re: Painting
| Painting | tgwalker | Rules/Strategy | 4 | 16-01-2008 13:40 |
| Automotive painting | sanddrag | Chit-Chat | 3 | 02-08-2006 22:24 |
| Painting PVC, HELP!!!! | Freddy Schurr | Technical Discussion | 8 | 30-01-2006 21:38 |
| Painting Aluminum | Yan Wang | General Forum | 17 | 15-05-2004 18:23 |
| Painting Hinges? | Sscamatt | General Forum | 3 | 27-02-2004 05:53 |
