Go to Post Welcome to CD! You'll find this is basically the coolest place on the internet. - Donut [more]
Unread 18-05-2008, 01:17
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
3 wheel vs 4 wheel omni
What are the pro's and cons of each one, 3 wheels set up in the "kiwi" configuration versus 4 wheels each at 45 degrees. (besides the fact of cost and programming)
Thanks
Unread 18-05-2008, 07:11
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Re: 3 wheel vs 4 wheel omni
Assuming that there is one motor per wheel, and that all motors used are identical:
With a four wheeled system you get between 50% (when translating along the axis of a wheel) to 71% (when translating 45º from an axis of a wheel) of your total force of your four motors. Therefor, you are harnessing between 2 to 2√2 (~2.83) motor's worth of force.
With a three wheeled system you get between 47% (when translating along the axis of a wheel) to 68% (when translating 30º from an axis of a wheel) of your total force of your three motors. Therefor, you are harnessing between √2 (~1.41) to 2 motor's worth of force.
The three wheeled system has a lower range of efficiencies, but only very slightly, but has less total force (due to the fact it has one less motor). This reduction in force results in slower acceleration and less pushing power.
Four wheeled frames additionally are able to be spaced further apart, resulting in a much larger support base (as you can cram the wheels into the edges of the size requirements). This results in a few things. The biggest advantage is the increased stability gained by this base. Additionally it creates a bigger "lever arm" for the wheels, as they are further away from the center of gravity of the robot, resulting in them being able to apply more torque to the bot*, which increasing your ability to rotate (or resist being rotated).
Four wheeled frames are also easier to construct from "standard" kitbot frames (or similar), as they only require 90º angels, as opposed to 120º and/or 60º angles needed for a three-wheeled platform.
Four wheeled drive bases often weigh more, as the frames tend to be larger, and you need an additional wheel and motor.
*Please note, this is torque to the bot, not the wheel's torque. It won't increase your pushing power, but rather the bot's ability to spin.
Being correct doesn't mean you don't have to explain yourself.
Unread 18-05-2008, 08:56
Billfred's Avatar
Billfred Billfred is offline
Actually, a kiwi drive can be done using kitbot components without too much fuss. Consider this CAD drawing I did; the only custom parts were the corner brackets (which can definitely be improved upon compared with the ones pictured; remember that I was a marketing major trying to hack it in a CAD class).
The design above was actually built, though never quite perfected, and is probably somewhere in the basement of USC's mechanical engineering building.
1727 - Killing our Omni Wheel zim2411 Robot Showcase 15 19-02-2008 17:42
Omni Wheel Kilroy0846 Technical Discussion 14 20-01-2008 23:09
Omni-Wheel Design fightoplankton Technical Discussion 7 08-01-2006 23:49
pic: Dual omni-wheel Richard Wallace Extra Discussion 17 05-12-2005 10:38
Omni wheel supplier JamesBrown Technical Discussion 5 25-02-2005 13:27
